-   -   grill blocking, does it work from the back? (https://www.fuelly.com/forums/f14/grill-blocking-does-it-work-from-the-back-6405.html)
2000mc 10-16-2007 05:35 PM
i was thinking of doing some grill blocking. i was wondering if anyone had tried blocking air with panels held up to the back sides of grill openings? would this be just as good in some cases, or would smoothing the front side make much more of a difference?
SVOboy 10-16-2007 05:41 PM
Smoothing out the front would make more difference, but from the back is good if you're going for a radiator block without any sexy exterior mods.
thisisntjared 10-17-2007 01:15 PM
the difference would not be as great because of a parachuting effect. i wonder if recessed blocks would actually be worse...
trebuchet03 10-17-2007 01:42 PM
2 Attachment(s)
It should help -- you're going to create a high pressure zone inside the cavity, and if you could see it's shape, it should be "cone-like."
It would be better to be completely flush, but it's surely better than letting air impact a vertical "wall" of a radiator :p
Here's what an apple does -while it's no car, it does have a cavity that's blocked...
https://www.gassavers.org/attachment....1&d=1192657327
MnFocus 10-17-2007 01:46 PM
It may not be quite as good ...I don't think I'll notice the difference.
thisisntjared 10-17-2007 04:59 PM
thanks for the pic! now i definitely think it will be better than no block at all. i was recently thinking about doing the same thing today because i want anyone that sees my car to think it is completely unmodified(theft deterrent) but i still want to block the grill for the winter months. i do not want to sit for more than a minute to let my car warm up.
i think i want to go for a degree in aerodynamics.
MnFocus 10-17-2007 05:04 PM
my temporary test block :
https://www.gassavers.org/garage_imag...mhlnuzxt9l.jpg
It was still in very good shape after a couple months ! Its now made of 1/8" lexan and painted satin black Krylon Fusion-I deleted the 1"x6" cut out as well as 90% of the lower grille .
91CavGT 10-17-2007 05:20 PM
I blocked off the back of my grill on my truck, but every time an 18 wheeler passed me the wind blew the duct tape off.
GasSavers_Ryland 10-17-2007 09:06 PM
well, the stock grill block that came on the civic VX sat behind the grill, it also helps by preventing air from entering that less then airodynamic engine compartment and going under the car.
trebuchet03 10-17-2007 09:31 PM
8 Attachment(s)
The funny thing is... I'm not an aerospace major - I'm mechanical :p But I still got to play with a water tunnel, and now I'm developing a fairing for another human powered vehicle :thumbup:
I wanted to compare apples to oranges in the aerodynamic sense... I couldn't find an orange though :/
Just for fun.. I here's a few more pictures from my collection :p
I did the calculations awhile back, and IIRC the equivalent wind speed was something like 6mph for those car models... This tunnel is just for flow visualization ;)
Check out the pressure wave formed behind the shield - that's actually very significant (think sound pressure wave in some cars when only one window is open)
https://www.gassavers.org/attachment....1&d=1192684955
Very Slippery Shuttle
https://www.gassavers.org/attachment....1&d=1192685112
Toy Car (I brought a box of die cast Porsche cars)
https://www.gassavers.org/attachment....1&d=1192685175
Here's the water tunnel
https://www.gassavers.org/attachment....1&d=1192685360
Sorry to thread jack there :p
