One of my custom stats does not work.
I have a problem with one of my custom stats not working. I use 12 separate stats, this one happens to be number 9 (as you read left to right, top to bottom)
This particular stat is setup to show best price per gallon for all time. It just simply says: "Stat Not Working (15)" I have tried setting it to other things, those seem to show up, but that particular stat will not. This affects both my vehicles and any other vehicle I look at. Currently using Firefox 3.6.16 on XP Pro SP3 However the same thing happens on my netbook which is running Windows 7 Pre SP1 with Firefox 4. |
Forgot to mention, it used to work, when the site first went live, then apparently it quit at some point, I can't say exactly when. I have known about it for over a week, but figured I would wait to see if it was just a bug or something you guys were working on still.
Hopefully its no biggie. |
Thanks for the detailed bug report. I'm seeing the same thing--we'll look into it.
This should be working now.
Yep. Nice work. Thanks!
