-   -   How many MPG's off is my car because of slightly larger tires?? (https://www.fuelly.com/forums/f8/how-many-mpgs-off-is-my-car-because-of-slightly-larger-tires-6245.html)
panamacolin 09-30-2007 04:52 PM
Hey guys!
Just wondering how many mpg's my cars tripometer will be off because the VX stock tires are 165/70-13 and I am running 175/70-13...
Thanks in advance, everyone on here has been great!
mrmad 09-30-2007 05:14 PM
Here is a circumference calculator on discounttire.com. You might want to try to verify how accurate your odometer is overall. My CRX has 185/60/14s on it which should be about 4% larger in circimference then the stock 13 tires. I used Google Earth to measure about a 30 mile section on my commute to try to see if I was really getting 4% lower mpg then I was calculating, and it turned out the odometer was pretty much dead on with the 14" tires. I guess the stock odeometer is about 4% high.
https://www.discounttire.com/dtcs/infoTireMath.dos
panamacolin 09-30-2007 05:38 PM
2.54%...is what it says...mind running running it for me to see if I did that correctly...
Thanks!
Colin
mrmad 09-30-2007 05:45 PM
Tire calculator says 165/70/13 has a circumference of 69.41 and 175/70/13 is 71.14. This is 1.73" more. 1.73/69.41 is 0.0249 or 2.49% more. The Sunday night football game must be pretty boring to make me want to calculate tire circumferences.
cfg83 09-30-2007 09:49 PM
panamacolin -
I used a GPS to calibrate/correct my odometer :
New shoes (aka tires)
https://www.gassavers.org/showthread.php?t=3699
CarloSW2
panamacolin 10-01-2007 05:58 PM
cool, ill have to try the gps thing
