VX Tailgate
If anyone would be interested in selling a teal VX tailgate I would be very interested!!! :D
Color Code: BG-33P-4 Location: Southern California |
I have a teal 92 Si tailgate. Where do you live? I'm in Calgary Alberta Canada.
If you're not aware of it, there are at least two different teal paint codes, so be sure you find the right one or it'll look quite a bit off.
Good luck...I was searching for one for my VX for a while since I'm not happy with the paint/body work on mine but I haven't found one yet either in the bg33p teal. |
I'll have to chase down the code for my teal. Where is the code documented?
I have a teal 1995 California VX with a dented tailgate! |
I think the code is on the driver side door jamb, is on my CRX.
SVO is correct, it's on the driver's side door jamb above the info plate.
I found it right where you guys said...Thanks a bunch!
Color Code: BG-33P-4 |
where'd you come up with your Alias? Albatross are impressive creatures.
remember that if you take that paint code in to an auto parts store they can often mix you a can of spray paint, $12 later you can paint any part of your car, finger nails, mail box, or hat, the exact same color as your car.
Still Looking
I'm still looking for a teal tailgate if anyone has suggestions that would be great.
The albatross name comes from a project I did on a type of soaring the bird does called dynamic soaring. It turns out that radio control glider pilots can also dynamic soar as well. Check out "dynamic soaring" on Youtube, the current speed record is over 300 mph using nothing but wind!! |
