-   -   Brisk spark plugs (https://www.fuelly.com/forums/f9/brisk-spark-plugs-5600.html)
unstable bob 07-30-2007 07:51 AM
Brisk spark plugs
I just installed some Brisk plugs in my Cavalier, and will be filling up in a couple hours to start testing. I will say the car seems to idle much smoother, and at a lower RPM.
https://www.briskracing.com/content/lgs.php
cfg83 07-30-2007 09:00 AM
Unstable Bob -
I keep thinking I have seen all the spark plugs out there, but there's always a new one I have never heard of. A "no indexing" firing tip in a Lambo, of all things? Maybe this is the secret to theclencher's success.
I have Denso Iridiums that seem to be working fine right now, but Saturns also use a "waste spark" system that reverses the polarity of the firing of the plug :
Spark Plug Comparison Test
https://www.gassavers.org/showpost.ph...8&postcount=19
I think your Ecotec does as well :
INVESTIGATING GM'S COMPRESSION SENSE IGNITION
https://findarticles.com/p/articles/m...11/ai_n9469461
... The ECOTEC engine uses a speed density-based fuel injection system, along with a waste-spark electronic ignition system. The waste-spark ignition is part of a unique Compression Sense Ignition (CSI) system that allows the powertrain control module (PCM) to determine proper engine phasing (cam position) without the use of a separate camshaft position sensor mounted near a rotating engine member. This article will explain how the CSI system operates. We'll also document new misfire diagnostic techniques that are made possible by die system s unique design. ...
I will be interested in your long term performance because I read at saturnfans that certain spark plug designs are susceptible to being fouled more quickly than others. My Denso's should be vulnerable, but they're working like a charm (knock on wood).
CarloSW2
unstable bob 07-30-2007 08:52 PM
Originally Posted by cfg83 (Post 66092)
Unstable Bob -
CarloSW2
Carlos:
Some interesting points there. I'll add "checking spark plugs" to my list of things to moniter. :thumbup:
unstable bob 08-04-2007 06:47 PM
My mileage for the tank I used while running the Brisk plugs gave me 36 MPG, up from 35. And this was with some "spirited" driving. Car seems to be running really well, and as noted has a very smooth idle @ a lower RPM then stock. :thumbup:
baddog671 08-04-2007 09:03 PM
Which reminds me, I need to check mine tomorrow:thumbup:
If you don't have a spark plug socket, it's ok to use a cresent wrench, correct?
cfg83 08-04-2007 09:09 PM
unstable bob -
Can you recall the before/after idle RPM? You can quantify your gas savings "at idle" with a simple RPM ratio.
CarloSW2
n0rt0npr0 08-10-2007 08:09 PM
unstable bob,
Ditto on the (Can you recall the before/after idle RPM?) question from Carlos...
And which spark plugs exactly with model number did you replace with these Brisk ones?
~Will
unstable bob 08-10-2007 08:22 PM
Originally Posted by n0rt0npr0 (Post 67690)
unstable bob,
~Will
Oh snap! I forgot about this thread...:eek:
IIRC, the idle went from 700ish to low 600-high 500ish. Didn't really think to do a before and after check. The plugs I replaced were AC-Delco 41-981s.
GasSavers_Red 08-10-2007 08:24 PM
Why is your Cavalier idling at a lower RPM? Far as I know its a computer controlled vehicle, so its idle should be more or less hard coded into the ECU. Logically speaking, plugs shouldn't change your idle speed
unstable bob 08-10-2007 08:40 PM
Someone else brought this up, and I really don't have an answer for it. *shrug* Guess it is like the azz dyno, you know the gains are there, but can't really prove it...:)
