Gm's Volt (i did a search)
I did a search and didn't see anything on the topic. But I thought this was interesting article.
------------------------------ One plug-in hybrid, a version of its Saturn Vue, would have an electric range similar to that of the Toyota car: about 10 miles. The other is an entirely new vehicle called the Volt, an electric car that would use power stored from the grid for the first 40 miles, then rely on electricity from an onboard gasoline-powered generator for another 600 miles. -------------------------------- The part about the generator is an interesting idea. Heck putting a small generator in the car I could disconnect the alternator lol instead of the solar panals. Here is the whole article.... https://www.technologyreview.com/blog/editors/17664/ |
Sounds like an ideal car. Use the batteries for the short commutes. For longer drives let a small gas engine run at the most efficient RPM to charge the batteries for the extended ranges. It might get poor mileage when running with the gas, but for most of us the daily commute EV part would work great.
korax123 -
Here is the Ford HySeries Edge plug-in Hybrid : Ford Edge Plug-In Hybrid https://www.greencar.com/index.cfm?content=ford_edge Quote:
Volt is a great idea. But its GM,,, they will screw it up...
I don't see why they are starting with generators for the electric cars, a large alternator would produce a LOT of AC power, and an AC motor could be used to drive the rear wheels with a voltage converter to convert to DC for the DC side of the house. Seems like it would be more efficient that way. Those dinky little alternators can provide 140 amps at 12V, a larger one used as a power generator, driven by a half liter gasoline or diesel engine optimized for the alternator it is driving, for hybrid car should be able to provide 300-400 amps at 120V, probably more than enough to drive a car at any speed. |
Nah, they won't even build it. IMO.
It would be cool to get a junk S-10 and convert it to EV then put that Home Depot generator in the bed of the truck and see how far you could go. GM states a 40mil range without the generator so I can make it to work and back home without even kicking it on. This car would be slick if it was under 18k I might buy one. |
