Smart plugs? Anybody tried this?
I just ran across this site and was wondering if anybody has tried this:
https://www.smartplugs.com/index.html Just wondering. M |
Sounds kinda like a system that has the coil built into the plug. Seems like it would be best suited for an engine that runs at a constant RPM and load rather than variable
Yeah, they use it on a lot of small gasoline engines.
ma4t -
Here's previous commentary on it : SmartPlugs 12-27-2005 https://www.gassavers.org/showthread....ght=smartplugs And this mentions it too : Pulsing Spark Plugs 06-18-2007 https://www.gassavers.org/showthread....highlight=plug CarloSW2 |
My dad's 02 Si hatch has coils built in with the plugs. No distributor.
These look like nothing more than a reinvention of 'hot wire' ignition, which was superceded some time ago by... the Spark Plug.
Next thing they will be rediscovering the wick carburettor. |
The current Civic hybrid motor has 2 plugs per cylinder, which fire at slightly different moments to optimize air/fuel burn. Try doing that with a distributor. |
Take your distributor and install sensors at the plug wires with low voltage leads to each coil on each plug and put a magnet on the rotor tip to trigger the pickups for each coil.
Wait a minute... It might not be so convenient for other cars, but AFAIK, all port fuel injected Hondas use sequential injection instead of batch-fire. Meaning the ECU only fires a fuel injector while the intake valves for it's preticular cylinder are open. The order of fuel injection should be identical to the ignition firing order, but offset by a crank revolution and change. Maybe the injector signals could be used to trigger the needed switching. Switching would stop while coasting, but that doesn't matter... No fuel is passing through the cylinders, and there's no point in trying to ignite air. |
