-   -   Filling Gas Tank (https://www.fuelly.com/forums/f8/filling-gas-tank-4951.html)
Bubba Bob 06-11-2007 07:20 PM
Filling Gas Tank
What's the best way to fill your vehicle with fuel?
I usually just take the handle out after it shuts off the first time. Maybe round up to the next dollar when paying with cash. I figure all the pumps shut off at about the same time, so why chance wasting gas by overfilling or having it heat up and overflow later?
slurp812 06-11-2007 07:27 PM
You know a funny thing happened to my G/F's 02 Monte, she waits till it shuts off, then runs it slowly till it about runs out on the ground. That practice was causing her CEL light to come on, in fact she ended up taking it in, and they told her that! I used to do 2 shutoff's one fast, and then slow. Now I just run the pump full blast till one click...
Hockey4mnhs 06-11-2007 07:31 PM
yup one click outher wise it shoots all over the place
rvanengen 06-11-2007 07:42 PM
I fill till first stop/click, and then round to the nearest $.05.
NewsFlash 06-11-2007 07:49 PM
Good question. I USED to run the pump up to the nearest amount ending in 5 or 0. In the past month I've read an article on the Car Talk website, and brothers "Click and Clack" say NOT to do so for good reason: you can ruin your gasoline-vapor recovery system, so they say.
https://www.cartalk.com/content/eco/tips.html
Tip number 3 tells the tale. I do not consider myself a "tree hugger" but there are good tips on this webpage. Enjoy!
kickflipjr 06-11-2007 08:03 PM
I hold the trigger full blast and stop once it clicks. Then I give it a jiggle after it clicks to get out the last few drops.
Fourthbean 06-11-2007 08:23 PM
One day I filled up (stopping after first click) and then parked my car pointing up a hill. When I came back (4 hours later?) there was gasoline on the ground. lol
Ya so I definitely wouldn't do more than one click in my car, though that is probably just a "my car" thing :).
I like the theology of most pumps will probably shut off about the same time.
SVOboy 06-11-2007 09:02 PM
There's no option for "Let the gas pump person put as much in as he/she feels like."
atomicradish 06-11-2007 09:28 PM
I run it to one click every time so that I can have the most accurate FE measurements.
Before I became FE obsessed, I would always run fill it up until you could see gas. My dad has done that for the past 30 years, done it in every car we've ever owned, and nothing has ever came from it. I don't buy that it's a potential problem. Usually the pump cuts off pretty early anyhow.
SVO, they have people to pump the gas where you are? I don't know of anywhere around here that does that.
SVOboy 06-11-2007 09:32 PM
I think only two states require stores to pump. Increases jobs and all that.
