Hypermiler?
What does it take to reach hypermiler status and how does one get the tag in the body of the post if they reach that milestone?
30% over epa combined. then you can go into your "garage" and copy whats in box at bottom and then go to your control panel and past it into your sig and will show when you post.
Is there a way to also make Hypermiler be dependant on a larger sample of gas log entries, or have a rating to perhaps do 50% city? |
While we are on this topic, how do I even get the log to appear on the bottom of my post that states my mph and %?
Put that code in your signature, which you can change using hte "UserCP" tab on the top. |
Not sure I should post my stats since they seem so low -- Oh well gives me a chance to see my progress. Thanks again --Z Entered my new gaslog entry and I went from under EPA to 11% over thanks to a good tank. Never thought I would get 35+ |
In the garage for my car, I'm using the "old" EPA mpg figures because my car model is older than 2008. Would it be considered cheating if I changed my EPA mpg values from the "old" (pre-2008) EPA mpg to the "new" (2008+) EPA mpg?
