Gains with Thin Tires? Lighter wheels?
On the tire side of things I was wondering two things:
1. Replacing my steel wheels with lighter weight alloy/Mag/whatever material wheels will give better MPG? 2. Replacing my stock tires with thinner ones give better MPG? Is the tire/wheel a part of a car that can greatly increase MPG when an optimum tire/wheel combo is used? Or will the gains be so small as to make this irrelevent? |
The tires will likely yield better gains. But.. you need to either test the tires relative to each other, or find the results of someone who has. For instance, on 14" tires, there can be a huge difference in the rolling resistance coefficient, Crr. Meaning that if you had the worst tires on, the car would require twice as much energy to roll compared to the best tires. Around town the impact is much more than at highway speeds, where aerodynamic drag dominates instead of rolling drag. Neway, as long as you buy the proper tires, they'll give a much bigger bang for you buck than lighter wheels.
For instance, a 2,000lb car weighs ~10,000N (Newtons). Rolling resistance is just the Crr times the weight. Lets say lighter wheels drop 100lbs off compared to stock, and better tires drop the Crr from .010 to .007 since you probably don't have the worst tires on, but not the best either. Stock rolling force is 2,000lbs*.010=200lbs Light wheels- 1,900lbs*.010=190lbs Better tires- 2,000lbs*.007=140lbs Better tires will also probably be cheaper, especially if you need to replace the stock ones. This won't directly translate into 30% better efficiency via rolling resistance, since you're also reducing engine efficiency. But it will be a significant improvement nonetheless. |
I do agree with you, that a good tire can do lots for increasing MPG over a bad one.... |
2 Attachment(s)
When the weather turns nicer I'm going to try an A-B-A test with the two 'donut' tires I have for my car. The little donuts can be inflated to 60psi and are real skinny.
Attachment 337 |
That money would definitely better spent on synthetic engine and gear oil, aerodynamic modifications, or changes in gearing imo. You could also drop hundreds of pounds for free by removing unneeded items/weight from the car. |
"That money would definitely better spent on synthetic engine and gear oil, aerodynamic modifications, or changes in gearing imo. You could also drop hundreds of pounds for free by removing unneeded items/weight from the car."
I have done the synthetic engine oil, but not the gear oil in my 5 speed manual trans. Does the gear oil really make a difference? |
I think so, because efficiency gains are cumulative. Assuming a 3% synthetic increase for both oils with 20% engine and 80% transmission efficiency.
stock-.2*.8=.16 engine oil-.206*.8=.1648 engine and gear oil-.206*.824=.169744 Just oil results in a 3% gain, and gear oil and oil results in 6.09% gain. Now, synthetic gear oil compared to normal may result in more or less than a 3% difference, just like engine oil. But the point is that changes are cumulative and the total is greater than the sum of it's parts, iirc one of the lube companies did a test on a fully loaded big rig and saw a 10% increase in efficiency with all synthetic lubes, including bearing/axle grease. Less wear is just a bonus, the increase in efficiency and longer intervals between changes should make up for the price increase on an average car iirc. |
FYI, on the smart fortwo, when the diesel version is equipped with 175/55-15 front tires and 195/50-15 rear tires (like I have), the fuel consumption goes up by 5.8% in the EU cycle fuel economy test (compared to the regular sizes of 145/65-15 front and 175/55-15 rear). That sounds like a lot, but it's only 0.2 L//100 km (and the wider tires and wheels have huge benefits in terms of roadholding).
So losing 3 cm off the width of a front tire should make a measurable difference. Also, low rolling resistance tires like the Continental Eco Contact or Michelin Energy should help as well. Would you recoup the cost of new tires and wheels if your present ones don't need replacing? No way! |
