Liters/100km signature hack
...hack deleted since Matt was kind enough to add the Liters/100km to the standard signature...
reminder, I did say: "Note, this is just a stopgap, no guarantees that it will work always and forever." I won't be maintaining the hack now, so it will eventually fail. |
Just done mine :)
Cool!
note: it can take a couple hours to update itself after adding/modifying your gas log. |
Just completed signature hack. Now to wait to see if it updates when I next log on.
<edit>Thanks for making the instructions easy enough that even I could follow them.<end edit> <edit#2>easy come, easy go. Thanks Matt for incorporating the data in the box to the left<end edit#2> |
Thanks!
This will help me brush up on my metric. (edit) I don't see mine. But it shows in my user cp (/edit)
Hmm, the aveo (gid=9) just wont work without some gaslog info (no MPG info on it to convert). The protege (gid=249) https://www.uusog.org/custsig.php?garid=249 seems to be working ok.
Tanks Skewbe!
THanks for lighting the fire.
Instead of allowing an option or viewing L/100KM or MPG, I'm just going to display both. First I will fix the signature and data under the user name, and then I will alter the input form to allow for Liters/KM or Miles/gallons. Should all be done later today, or tomorrow at the latest. |
Awesome Matt!! I'm there, forget this hack yall
