Someone Has Built An Efie ?
Hi to All!
I has built an EFIE and into an AFRD. I want to compare readings of leds, flickerings and functioning at idle and higway. Thankfully |
That was soooooooooooo funny! :D |
Clencher...Is that a rabbit with a flat-head? :D
That's not a bunnie with a pancake on its head . . . that's a bunnie with TWO pancakes on its head.
WTF???
Is there a problem with writting full words? at least use the full phrase at least once (in brackets?) so you are not just reading thru a whole list of initials without having a clue what they meen or are we too good for that, it does after all seem like a good way to keep this a nice little elite club, keep those pesky outsiders where they belong, in the dark! |
I agree, there are way too many TLAs tossed about.
(TLA=three letter acronyms) :D |
As always, tune the efie to your particular engine, the instructions are pretty accurate actually. Using an afr with the efie in my opinion is a great idea, you really need some feedback for how the efie is affecting your fuel mixture, seat of the pants tuning leaves too many opportunities for error. |
Electronic Fuel Injection Enhancer = EFIE - modifies the Oxygen Sensor Signal to the ECU - Engine Control Unit (two are needed if two oxygen sensors are being used)
Air Fuel Ratio Display = AFRD |
