Gasoline volume does change at the pump!
https://www.nytimes.com/2006/12/15/business/15fuel.html
Mwahhaha. Quote:
YAY! **** big oil!
So what I see is that pig oil has worked hard to make sure things work this way and they'd really prefer to have it continue. They think that's reasonable. If you don't believe them, just ask them. ;) |
I don't see where there would be much variation in gasoline temperatures. The storage tanks at your local gas station are underground, so the temperature of the gas stored in them would end up stabilizing at your local deep ground (cave or well water) temps. So it doesn't matter if you are gassing up in the day, night, winter or summer, the temperature of the gasoline will remain about the same.
The fact that there is a lawsuit doesn't mean it's factual. As far as we know the lawsuit was initiated just so that big oil would settle out of court and make a few lawyers rich. That type of thing happens all of the time, especially in California. |
Virtually all the gas pumps I've used in my city have a label stating "Fuel Volumes Corrected To 15*C"
Otherwise, I'd always fill my tank at night, so when the temperature raises in the day, I'd have 'more' gas. Although probably less BTU per fuel unit. |
Don't forget that the fuel is transported in a truck many miles and will heat up during that trip - or cool down. I'm sure they don't want to be loosing volume when in the truck . . . do they pay by what they pump into your car??? I wonder what the ratio of cost of heating the gasoline to the volume expansion savings is.
