-   -   Not really much of a post but... (https://www.fuelly.com/forums/f11/not-really-much-of-a-post-but-3388.html)
omgwtfbyobbq 11-27-2006 07:40 AM
Make sure your transmission fluid isn't overfilled, it seems to suck up a decent amount of power if it is. The last time I filled mine was about four years ago, when the most I had done up to that point was changing the fuel/oil filters, so I was t3h suck and overfilled. After a drain/refill I've seen significantly higher mileage in relatively adverse conditions, so I'm pretty sure too much fluid in the tq converter can seriously hurt efficiency. :o :thumbup:
