Place your bets on the smart...
I'm aiming for at least 100 mpg US based on repeatable round trips of at least 100 miles.
Here's the plan for the smart, as I see it today: Current (stock) front tire width is 145mm, rear is 175mm I've got some steel wheels in trade now, and will be putting the fronts from this set onto the rear. In Europe, the car is rated for 3.1 L/100 hwy with the 145/175 combo - but with a wider combo (175/195) it is rated at 3.3 So there is roughly a 6.5% penalty based on the extra 50mm per side of the car. My best guess is that I can gain 4% economy by putting the narrower tires onto the rear. (Note: 2000-2002 smart diesel models came with 3.5 inch front wheels instead of 4 inch, and had 135 mm tires as stock... I could acquire those, but not at 'any cost'...) I'm going to do a wheel skirt mod. Not going to get technical on this one - simply put, I'm going to use Darin's number of 3% as a gain. Vortex Generators - this one could be interesting. The smart is .36 cd I think, and it's abrupt end at the back seemingly make it a good candidate for the VG mod. I'm going out on a limb and saying another 2% gain there. These mods collectively add up to a 9% potential improvement. Being that I can already get 93 mpg US on a round trip in cold weather (39-45F) without my Milligan's fuel conditioner - getting repeatable round trips of 100 mpg is very realistic. The question remains at what speed... I'll aim to do it at 50 mph. I don't need to pulse, glide, or go fishing to do any of this... I'll simply set the cruise and go... There are a host of other things to play with, but they are all small percentage items IMO. Thoughts? I do plan on keeping good records of these mods, and posting the results. |
First, good luck!
I'm surprised that the CD of the SMart is so high. Car engineers continue to amaze me when they build "high MPG" cars with horrible drag coefficients. As for the speed, I think the scangauage is the best critic. Find the "sweet spot" and let it rip. I have a road trip planned for California in a month. 1 1/2 years ago the same road trip yielded 46 MPG in my 89 Civic LX. I'm hoping to break 50 mpg in my Fit. I plan on going 65MPH the entire way, travel time be damned. Unless, of course, I get better MPG at 70mph. |
Well, 40 mph netted the 93 mpg to which I refer... so that is a likely place to start. Thanks!
The only potential fly in the ointment: at 40 mph, the savings from the aero mods listed will be smaller than estimated. e.g. The 3% improvement I measured from wheel skirts was taken @ 95 km/h / 59 mph.
I'm not saying don't do the aero mods. Just that they won't contribute as much if you drive slower than the test speed. Still, I won't be surprised if you pull it off. :) EDIT: also, you should get better fuel economy if you don't use cruise control, and instead allow the vehicle speed to rise/fall with the grade. |
The beauty of the smart is that, when coasting in gear, it doesn't use fuel... I'll have to dig up the technical explanation...
...the same is true with cruise downhill - it may still stay 'engaged' (ie: ready to pick it up at the bottom), but the car may not use any fuel if the grade is sufficient... the car will speed up as well, if it's REALLY sufficient... The drive by wire system in the smart loves cruise - yes, I can get get great mileage manually too... so I will try tests with and without cruise... I am hoping to do this at 50 mph - so hopefully my wheels skirts will offer similar results. (I have achieved 105 mpg on a non-round trip going 50 mph). |
Does the smart transmission truly "freewheel" when you lift off the accelerator? I understand diesels don't engine brake much.
And do you happen to know any smarties around Brockville, ON who would be willing to show me his/her smart? I'd like to see one up close sometime. (Or get a ride, or better yet drive one. :) ) |
I'm working on getting you matched up with a smart owner.
There were some discussions about the fuel cutoff here. And somewhere else as well, but finding the thread at CsC is a tricky thing... I need to review further to collect up the pieces of discussion... |
In the words of the great Nascar legend, Dale Earnhardt: "Don't tell me what you're going to do, show me what you've done". Best of luck, COZX2 P.S. What diameter and bolt pattern are your wheels? |
As much as I trust the Scanguage numbers within a certain range, there are some *glitches*, and I have already seen them... The wheels are a three-bolt pattern, and you're lucky to get tires here for stock size... but seeing as 800,000 of these exist in Europe, there's lots there. |
