5 wire o2 sensor blues
Alright
Got a "used" 5 wire o2 sensor today for free that a friend of mine took from a running car. I was throwing a code 48 which was Lean Air fuel sensor.. Everything dealing with my o2 sensor is hard wired. Running a cx wiring harness. where i repinned at the ecu to allow for the 5 wire. I am pretty sure that everything is wired up right or i think i would be displaying more codes than it is. I have the right ecu incase you are wondering. So anyways, the car is no longer throwing a code 48 It has now moved on to a code 41. From what i looked up it says that its a bad o2 sensor heater. I am wondering a couple of things. first of all, does this mean the new o2 sensor i installed is even worse than the old code 48 one? second, is there anything i can do to trick the ecu, or hard wire something into the sensor itself. i searched btw , according to svoboy : "You can run a 1k resistor from POWA to A6 to get rid of that code 41." Is this also true for a 5 wire? and what effect will it have on gas mileage if the ecu is tricked into thinking the o2 sensor heater is working? let me know guys I am trying to be a cheap basterd as long as i can. $300 for an o2 sensor is ridiculous. Making this one work out for FREE would be so much better. |
Get one on ebay for $170... brand new. Just search for "L1H1"
oxygen sensors have been known to suddenly stop working properly when you switch them out. |
krousdb -
CarloSW2 |
ok, got a chance to mess with my wiring.....
now i am back to a code 48. I think the wiring is the issue here soo... I need to know, the pinouts for the 5 wire o2. I am wiring directly from the o2 sensor wires (no clip, harness etc...) to the ECU. I need O2 wire color to ECU pinout location. I have searched everywhere. I had the info a long time ago but apparently i lost it somehow. If anyone can help with this let me know otherwise im still looking |
HERE is a link to a post I participated in on Honda-Tech when I was doing the opposite of what you were doing - I was taking a VX wiring harness and retrofitting it to accept a 4-wire o2 sensor. There's lots of tidbits of info in there like wire colors, ECU pins, etc. Dig through the post and see if it helps.
EDIT - check out my 2nd to last post in the thread....it's got the most info. |
Thanks
I just found that a few minutes before you posted it. im havent had time to decide if its helpful or not yet. its funny to see how many of you guys are on honda-tech when i search |
Im still looking
so far..... O2 sensor wires: red - sensor element positive Black - ground white- control element yellow - heater - Orange - Heater + Ecu: d14 - heater a6- heater so far it looks like yellow and orange will go to d14 and a6? can anyone confirm any of those? |
well i checked my wiring
here is how i have it wired up...... o2 sensor wire ---- ecu pin out WHITE to d16 (VREF signal) YELLOW to d14 (PHO2S O2 sensor White, heated 02 sensor Signal, 0.4-0.5V when ignition is turned on; drops to less than 0.1V within 2 minutes ) RED to a25 (Battery positive from Main relay, Battery Voltage with KOEO) BLACK to ground (to vehicle ground in engine bay) ORANGE to A6 ( PO2SHTC O2 sensor (heating element) Org/Wht, Battery Voltage with KOEO ) I am still throwing a code 48, after re wiring it this way.... What do you guys say? wired up correctly or not? |
dont' wideband o2 sensors put out 1-5 volts? I also alwasy thought they needed a seperate controller to control their membrane or seomthing like that, if your using the stock CX ecu, i woudln't think it would have these abilities in it.
