How do you post cars MPG from gaslog?
How do you get your cars gaslog average in the box to appear in posts and cars with avitar? I started the long task on both the Metro and Fit, have several thousand miles on both cars to add still......
Here is the Fit for May/June: https://www.gassavers.org/garage/viewgaslog/223 |
Weird, I just put mine in and it showed up....
All of the stats are 90 day averages. This is to provide people with an idea of your current MPG, and it also drops old tanks in the event that they damage your lifetime MPG. All of your gaslog entries are older than 90 days.
If you want them to show up, start from the most recent tank and move backwards. As I mentioned before, I'd be more than happy to import your entries for you if you provide them to me in a comma-seperated format date,miles,gallons,price,notes etc.etc. Typing it in this format would be much faster than submitting them one at a time. Quote:
OK, I see I need 90 days of data now, thanks. Thanks again on the offer, but I feel I can enter it quickly as typing it, excluding the date, you cannot tab to enter, requires mouse?
As for the last question, I'm unsure exactly what you mean. |
I think he means when your entering the data in the garage you can't tab between the fields, you have to use the mouse to click on the next field, at least I did. Not a big deal, just different.
ETA: I just tested and was able to tab between fields. Perhaps it doesn't work in certain browsers? I'm using firefox. |
