-   -   Honda NOID Light, Which to use? (https://www.fuelly.com/forums/f10/honda-noid-light-which-to-use-3224.html)
8Civic8 10-27-2006 09:47 AM
I want to check to see if my injectors are getting a proper signal to conclude wether its my injectors or something else (i get error code 16). They sell kits that iclude the followoing noids;
  • GM TBI
  • Bosch PFI
  • Ford TBI
  • GM PFI
  • Geo TBI
  • GM SCPI
Is it the Bosch PFI Noid that i have to use? Or is the Honda Noid not on the list?
Thank you in advanced.
SVOboy 10-27-2006 10:55 AM
I have no idea, but have you already checked your main relay and wiring (if you changed any wiring)? What's a NOID?
8Civic8 10-27-2006 11:19 AM
Yeah, ive ran through the honda manual a few times and everything checks out. I have proper voltage, the injectors are injecting gas, it leads me to replace ecu, i replaced the p07 with a p13 ( that i know is good). And i get the same message. Could it also be that i repaired the TPS and the idle is all screwy since i did not calibrate it (i didnt know i had to at the time i did it)? ( what i mean by repaired is that i got a jdm engine and the tps clip was broken but the leads where still there. I couldnt get close enough to it to sauder so i took it off and saudered some wires to it and put it back. I have a feeeling that it might be the irregular idle thats throwing off the ecu and making it think that its a injector malfunction.
Does anyone know if a 88 civic (D15 DPFI) TPS will fit a d15z1? THey should but i dont know.
Any idea?
SVOboy 10-27-2006 12:21 PM
Did you swap the wires on the TPS?
Also, are you using an injector resistor box or not?
8Civic8 10-27-2006 12:24 PM
Do you mean connect them improperly? I dont think so. could that be it?
SVOboy 10-27-2006 12:29 PM
For the tps you need to switch the two outer wires when you do the MPFI swap. Dunno if that causes a code 16 though.
What's your injector/resistor box situation?
8Civic8 10-27-2006 12:32 PM
I dont have one. I dont think the original DPFI wire harness had one. Where would it be if i had one. I didnt take one out, if i had one then its probably still there. Although, isnt it ussualy on the drivers side shock tower? because there is nothing there.
8Civic8 10-27-2006 01:00 PM
By the way, a NOID is a test light that checks for signal coming from the injector harness. It lets you know if theres a problem with the wiring harness.
Matt Timion 10-27-2006 01:26 PM
Noid?
https://www.paunchstevenson.com/photo...id-250x309.jpg
Avoid the Noid.
Silveredwings 10-28-2006 05:46 AM
Originally Posted by Matt Timion
Noid?
:Noid image:
Avoid the Noid.
He looks like he's annoyed.
