Tripcomputer with out pulse is that possible ???
Ok, so here I stand, my micra has no injector, has no speed sensor.
And I want a tripcomputer in that car now ! At the junkyard, I got a tripcomputer from a Saab 9000, or five maybe... Also got me a GM injectionsystem from a 1.3L engine complete with sensors. The micra was customized and I supplied: TPS, MAP, RPM and WAT besides that I let a injector laydown to simulate. Tapped speed at the original micra speedometer. And fuel at the simulator injector. Everything worked, I got values at the Saab computer and as a acc. it went up and in coasting got down. BUT ! The difference in total after a couple km was not that big, this was a mess.:mad: So now I had orderd a flowsensor just as I planned in the begining. :o Total cost for all junkparts: 60 USD Cost for one flowsensor: 80 USD Like all the time, you loose cash... // elg |
the Zemco was a non-FI trip computer and included all it's own sensors including flow, speed, in,out temp, and a cruse control functon. the only thing it didnt have that the scangauge does is instanious mpg.
i've seen them on ebay b4. i just wish in my pre driving stupid days i hadent riped apart my dads :( |
Took a bosch airflow sensor, put it before air intake at the micra.
1.3V at engine off. 1.9V idle. 70km/h 2.4V, 90km/h 2.70, all these data is relative and not absolute. The airflow was the same if I go in 4:th or 5:th gear, strange...Should have some kind of simpel logfunction. I´ll get there with an USB card soon. I will keep this in the micra for a couple of days and really work it out. Fuelsensor is yet to come. // elg |
heh.. I love this picture:
https://www.gassavers.org/garage_imag...uvjk4y3acz.jpg I'm curious. Is the Micra carburated? If so, you might want to look into the Zemco if your current setup does not work. |
