-   -   Have you had results with acetone. (https://www.fuelly.com/forums/f8/have-you-had-results-with-acetone-2761.html)
zpiloto 08-23-2006 03:42 PM
Anyone who has used acetone mixture and has had success please list mixture, make and age of car.
omgwtfbyobbq 08-23-2006 04:06 PM
Can't remember my mixture, pretty sure it was the suggested ratio. 1992 V6 auto Camry. I also had my coolant boil over for the first and only time.
tomauto 08-23-2006 04:08 PM
results
I couldn't tell. The only difference was that it made my idle speed lower. No harm.
zpiloto 08-23-2006 04:09 PM
Did you stop using it then? Also what kind of increase did you see before and after.
omgwtfbyobbq 08-23-2006 04:27 PM
Yup, it was on a run up the Cajon pass, after that I refilled coolant and stoped using acetone, no more trouble for the rest of the summer. I saw a difference of 2-3mpg over my best trip mpg (~34mpg) up to that point. The trip was hwy with the same distance, same traffic, same weather, and 55mph cruise control. The only problem was I didn't get in enough runs to determine if it was a glitch or if the acetone actually doing something, I also had ~5 miles our of 50 that were street, which could've influenced the results. I've heard it leans out the engine, but that's just heresay until I brush up on my chem... You wouldn't happen to know if your oxygen sensor is titanium dioxide, or zirconium dioxide?
zpiloto 08-23-2006 04:40 PM
No I don't. I think it's probably zirconium.
ZugyNA 08-23-2006 04:54 PM
3 oz per 10 G...'87 300ZX na...around a 20% gain...but some part of this was due to easier driving.
kickflipjr 08-23-2006 05:05 PM
It was inconclusive for me. without a scangauge It makes results very difficult.
GasSavers_scostanz 08-23-2006 05:38 PM
I used it for a little more than a month last year which translates into about a 1000 miles and didn't see any change in FE before, during or after using the stuff.
-- Scott
JanGeo 08-23-2006 05:40 PM
It matters that you got some good acetone and that you drive to save otherwise you dont' get an improvement - it allows you to get even better gas mileage with it that without it - it doesn't give you better gas mileage it allows you to get better mileage. I couldn't get past 46mpg until I used it now I get 50-55mpg.
