-   -   Gas cap (https://www.fuelly.com/forums/f10/gas-cap-2614.html)
zpiloto 08-03-2006 11:38 AM
Gas cap
When I take my gas cap off for a fillup there is no hissing sound. Does anyone elses ride do this? Most cars you hear the release when you take the cap off. Just noticed it so I don't know if it's something new.
GasSavers_DaX 08-03-2006 11:57 AM
Mine usually only does the hiss if I'm really low on gas.
Matt Timion 08-03-2006 12:02 PM
I never noticed mine hissing until I moved to Utah. Could altitude have something to do with it?
SVOboy 08-03-2006 12:07 PM
I thought it was only sposed to hiss if your charcoal canister wasn't properly venting the gasses?
krousdb 08-03-2006 12:19 PM
I read that there is a valve between the gas tank and charcoal cannister that opens when the pressure gets so high. So at a certain pressure, the vapors will go to the cannister and await a PCV event that is suitable for vapor disposal. Pressures below that certain level, would be maintained in the gas tank, unless you remove your gas cap and get hissed at. Maybe your cap leaks?
SVOboy 08-03-2006 12:21 PM
Iono if my car does it or not, it's illegal to self-serve in NJ. I do know that it passed inspection though, so unless it's developed a leak since then I doubt it does.
zpiloto 08-03-2006 12:25 PM
They don't pressure test the cap here. I'll probably just replace it. There under 15 buck.
zpiloto 08-03-2006 12:32 PM
Here's an interesting program in Ohio. They found the highest failure rate(though small) on caps on vechiles made between 95-99.
https://www.tmacog.org/CommuterServic...p%20Report.pdf
SVOboy 08-03-2006 12:34 PM
Someone (me) needs to get their act together and add stuff like that to the FAQ.
chesspirate 08-03-2006 02:12 PM
My new Yaris doesn't hiss, and niether did my '91 S-10, but my wifes '87 Civic hisses loud.
