GS FAQ/Glossary, Busted/Confirmed Mods, Archive
Busted/Confirmed Mods:
Acetone: I say it's busted (I tried it once, but FE went down due to weather) https://www.fuelsaving.info/acetone.htm https://www3.telus.net/metro/log/nov0305.htm https://www3.telus.net/metro/log/nov1805.htm Aerodynamic Mods (general): Confirmed https://www.kenworth.com/brochures/FuelEfficiency.pdf Air-Bleed Devices: Busted (Bad for pollution though and illegal in most areas) https://www.fuelsaving.info/air_bleed.htm Alternator/Accessory (AC, Power Steering, etc.) Belt Removal: Confirmed https://www.gassavers.org/showthread.php?t=1074 Boattail: Confirmed https://www.greencarcongress.com/2005...at_tail_d.html https://www.maxmpg.org/the_cap.html https://www.nasa.gov/centers/dryden/p...ain_H-2283.pdf https://www.osti.gov/fcvt/2000-01-2209.pdf Caulking: Really hard to test - how would you A-B-A it? (Hmmm...Scotchtape? Might be crazy enough to work! Thanks zpiloto!) Driving Technique: Confirmed...over and over and over Electrical Mods (grounding/stabilising): Plausible? https://www.fuelsaving.info/electric.htm Ethos: Busted https://www.gassavers.org/showthread.php?t=908&page=2 https://www.gassavers.org/garage.php?do=viewgaslog&id=28 https://www.fuelsaving.info/ethos.htm Front Wheel Skirts: TBT (to be tested) (IMO most aero mods work) Fuel Catalysts: Busted https://www.fuelsaving.info/catalysts.htm Grill block: confirmed https://www.metrompg.com/posts/grille...ing-part-1.htm https://www.metrompg.com/posts/grille...ing-part-2.htm Hydrogen Generators/Injectors: Plausible? (good theory, but impractical?) https://www.fuelsaving.info/hydrogen.htm Ignition Enhancers: https://www.fuelsaving.info/ignition.htm Intake/Exhaust Mods: TBT Increased PSI: Confirmed (need a link) K&N/High Flow Air Filters: busted https://www.metrompg.com/posts/air-filter-part-1.htm https://www.metrompg.com/posts/air-filter-part-2.htm Lightweight oils: TBT LPT (Light Pressure Turbo): Confirmed https://www.autozine.org/technical_sc...h_engine_3.htm https://en.wikipedia.org/wiki/Turbocharger https://autospeed.drive.com.au/cms/A_2664/article.html LRR (Low Rolling Resistance) Tires: Confirmed https://www.greenseal.org/resources/r...resistance.pdf Magnets: Busted https://www.fuelsaving.info/magnets.htm https://www.kirotv.com/consumer/2220354/detail.html Mirror removal: TBT (monitor system electrical load may outweigh benefits IMO) Oil Additives (Slick50, Duralube, etc.): Busted https://www.fuelsaving.info/oil.htm https://www.carbibles.com/additives.html Platinum Injection: Busted https://www.fuelsaving.info/platinum.htm https://www.cbc.ca/consumers/market/f...pvi/index.html PCV Catchcan: TBT Rear Wheel Skirts: Confirmed https://www.metrompg.com/posts/grille...ing-part-2.htm Tire Pressure (increased): Confirmed https://www.gassavers.org/showthread....highlight=tire Undertray: Confirmed (need a link) Vortex Generators: Busted https://www.fuelsaving.info/turbulence.htm https://www.kirotv.com/consumer/2220354/detail.html WAI (warm-air-intake): Jury is out - may be vehicle dependent or mostly improve winter FE https://www.metrompg.com/posts/wai-test.htm I'll think of more, but please add whatever you feel like or mods you would like to see busted/confirmed. Also, I saw an older Mythbusters last night that I hadn't seen before. They tested AC on vs windows open FE. I think their testing methods left a lot to be desired and they should have run it more than once, plus they only tested at 45 mph due to safety conditions on the track. Windows open won by traveling an extra 30 miles on 5 gallons of gas. It's a large enough margin that I'm certain it would be fairly consistent, but I'd like to see the same test at higher speeds (and swapping methods per vehicle, and repeatability, etc). |
Eventually we'll streamline this into an actual wiki for the site.
lol there goes your thread
just ask |
Nah, you suck, I'll add something right now, I think, if I can find it.
I added some stuff, as more things enter, organization will as well, :p
EOC = Engine Off Coasting (user diamondlarry)
CODFISH = Coast On Demand Forced Ignition SHutoff (user 95metro) ICE = Internal Combustion Engine |
Thank you, sir, I will edit up some stuff right now.
EV = Electric Vehicle
HPV = Human Powered Vehicle ECU = Electronic Control Unit VSS = Vehicle Speed Signal NiMH = Nickel Metal Hydride There should be a howto for EOC restarting, the clutch start. I've done it a few times now, but I still smell fuel, which can't be good, and it takes a while. I'm obviously not doing something right. |
Um...CODFISH was mostly a joke. However, I guess it has been used here and there now so it may as well stay for reference.
Wow do I ever feel special? I ask and **poof** glossary.
Thanks guys! |
