Alternator v. no alternator - 10% gain @ 70 km/h
FYI, other GS threads that talk about alternators are:
Anticipate any difficulties switching belts on the roadside? A-B-A testing is going to be a pain...good luck! Us yocals without instant mpg readouts really, really, REALLY appreciate the effort!
Back when I was messing with my alternator, I measured the electrical loads of various things (using a shunt on the alternator output). Not a super-exact test, but it should give a ballpark for smaller cars.
I tested at both voltage settings of the alt, where 14.4 is typical alt voltage, and 12.7 is similar to a fully charged battery. The idle current is subtracted out of the other settings. Idle: 128w @ 14.4v, 89w @ 12.7v Rev up to 3500 rpm: +35w, (not tested) Heater fan setting 1: 55w, 38w Setting 2: 98, 67 Setting 3: 141, 99 Setting 4: 189, 135 Marker lights: 95, 71 Full lights: 240, 179 A/C (heater fan subtracted, but including condenser fan): 163, 114 Defroster: 104, 77 Wipers 1: 48, 38 Wipers 2: 76, 64 Radiator fan: 144, 83 |
Does that mean that a/c is less of a drag than full blast non-cooled air? Of course you need to add the fan to the a/c, but still, do you get me?
drag
The AC will drag the engine directly and not present an electrical load except for any clutch power on the pulley and the blower fan. Nice measurements on the car electrical loads!! How about the car computer, fuel pump and ignition loads??
I have some results.
But first: Randy, great data. Thanks for posting it. What car/engine is it from? Preliminary results (I'll do a proper write up later with charts & margin of error etc. and post at the top of the thread): Speed 70 km/h / 43.5 mph A: alternator belt ON - 71.16 mpg (US) - avg of 3 bi-dir runs (6 one-way runs) B: alternator belt OFF - 78.08 mpg (US) - avg of 3 bi-dir runs A: alternator belt ON - 70.2 mpg (US) - avg of 2 bi-dir runs Notes:
I wonder if the effect will be different for larger engines, since the alternator is a proportionately smaller part of engine output at a given speed. Discuss. :) |
