Vortex Generators / Hmmm Airtabs
Wanted to see if installing vortec generators on the roof, trunk and front fender would improve FE. Did 4 runs on a 7.5 mile north south section of highway with cruise control set at 60. Did runs with a clean car, with VG on roof, VG on roof, trunk, and front fenders. Temperature was 93 and winds were out of the south at 15mph. VG's were made from hand out of aluminium.
#1N #2S #3N #4S Clean car 42.0 38.4 42.1 39.0 AVG 40.38 VG on roof 42.6 39.2 42.8 39.1 AVG 40.93 VG/roof/trunk/ff 42.9 39.1 42.9 39.0 AVG 40.98 That's only a 1.5% increase in FE and it looks like the VG anywhere but the roof are ineffective. https://members.cox.net/zpiloto/101_0070.JPG On the front wheel well https://members.cox.net/zpiloto/101_0071.JPG |
Cool. So were they hard to make? Seems like tin snips, a vice, and some kind of glue is all that is needed.
I think the roof is the only place you're going to see an improvement, since the rear window is at a greater than 11 degree angle, the boundry layer seperates from the window and causes greater drag. Or so says the things I've read and studied. =)
Definitely better on a boxier vehicle. You might try moving the VGs from the front fenders to the rear, just before the curve to the rear bumper and I use the term bumper loosely.
vg
Well I know a really boxy vehicle that shows greatly reduced MPG at higher speed that needs to be tested . . . my xB
a set of vortex generators
I like. If you were to sell a couple of those vortex generators to a fellow gassaver for his roofline, what would you charge him?
I know it may be some trouble to try the test again, but your vortex generators might be too close to the trailing edge to be of benefit. On plane wings, the generators are closer to the front of the wing, to keep the air attached over the surface of the wing. You might want to try moving them forward a few inches, and see if there is any difference.
One thing that might be of interest is this quick doc on the generators, on the wikipedia (https://en.wikipedia.org/wiki/Vortex_generator), where it says they actually increase drag. |
