"Gas Cubby" Needs to Be Updated - Won't launch app!
Last iOS update to 14.6 "broke" Gas Cubby. A decade of vehicle service records are now inaccessible.
Tapping the app returns message: "Gas Cubby" Needs to be updated. The developer of this app needs to update it to work with this version of iOS. Is there any way to recover the data? I see no option in the app store or my list of apps to upgrade. Thank you. |
Needs to be updated Fix
So, I had this same problem and I finally found a work around. This work around is long and convoluted. I hope it helps someone.
1. Download new fuelly app from app store. Create account on fuelly.com is you don't alreay have one. The new app can NOT see any of the old data or records. Next Sync your data with Fuelly, this may take 15 - 20 minutes When that is done Sync the Fuelly app with the web site. That should fix it. It worked for me, I then export data as CSV list. When I login to Fuelly 4 years of records appear on my dashboard, not sure what to do about that. I hope this can help someone. |
Remove a Vehicle
I bought a 2018 Rx 350 & want to remove the 2010 Rx 350, which I have sold.
