Miles since last fillup wrong
I've been worried my motorcycle was getting bad MPG the last several months.
Turns out it's Fuelly miscalculating. If I take the odometer readings and subtract previous from current, it's way more miles than what's showing in the "miles" column. If I use this alternate miles calculation, the MPG comes out just fine. It was correct until 8/22/2019, where it looks like maybe I missed entering a fill-up and forgot to mark it. All 10 entries since that have the wrong delta-miles. I went back and marked that entry as missed-fillup, but it doesn't change anything. Should I just start a new vehicle log? |
Similar issue happened with my "Jettka" (from web site):
previous fill-up - Odometer Reading 67798.0 current fill-up - Last Odometer: 68306.0 Calculated miles, driven between fill ups shown on the site - 148.00 !!! Deleting the last record and creating it anew - didn't fix this issue; Removing previous record didn't change the last one values re-creating previous record - didn't do anything with the most recent fill-up results - showing the wrong miles between fill-ups. |
