Have I selected the right vehicle options?
I have a Peugeot 308 Active e-HDi 112 EGC 5dr:
Transmission: 6-speed semi-automatic transmission (engine link) Top speed: 118mph Acceleration: 0-60mph in 12.1 seconds CO2 emissions: 109 g/km Tax: £20 per year Power: 82kW I have currently selected the following: Vehicle Type: Car / Truck Year: 2012 Make: Peugeot Model: 308 For Sub Model, I have the following options:
If I choose that, for Engine, I only get the following two options:
I could choose Other for Engine, then select Diesel as Fuel Type but what would I select for Cylinder Type?
Hello and welcome. I would either select other, and input your own choice, or request that it be added, there is a button somewhere, can take a while for you request to be processed though. I would assume L4 is correct as its a 4 cylinder.
Would be much easier if it were just engine size and fuel type, its been said many a time before, but these are the cards we've been dealt... |
The letters refer to the cylinder arrangement.
L= inline V= should be obvious W= is basically two V's mounted slightly offset so the engine is shorter in length R= rotary H= doesn't denote arrangement, but that the car has a hybrid system K= no idea |
K20 is a Honda engine. "K20 uses the short block with a deck height of 212mm."
So would you say "H4 DIESEL" is correct?
If not, I am happy to request an addition to the website but I wouldn't even know what to ask for. This is my vehicle, if it helps: https://www.parkers.co.uk/peugeot/30...-5d-egc/specs/ |
Pug is L4. Diesel.
