-   -   umm, hows this possible? (https://www.fuelly.com/forums/f8/umm-hows-this-possible-2031.html)
GasSavers_Danno 04-30-2006 09:54 AM
Today at a local gas station, I heard it was only 2.85 for 87 so I jumped at the chance :D and I only had 112.2 miles on the tank, but I thought why not fill up anyways. Well, I only got 1.633 gallons in :? Which means 68.7 mpg... :jawdrop: how is this possible? Is it off because I didn't drive far? The nozzle kept clicking off, I must have tried filling up about 5 more times but it would put about 20 more cents in and stop again. Whats the deal? :O
Matt Timion 04-30-2006 09:59 AM
Re: umm, hows this possible?
The "click method" is probably the most accurate way of measuring fuel if you:
1) use the same pump
2) don't fill anything less than 5 gallons.
I'm guessing it was a combination of both of these that made your MPG higher.
GasSavers_Danno 04-30-2006 10:13 AM
Same pump as always, just
Same pump as always, just heard it was cheaper today so I went lol :P
So its reading inaccurately is what you mean?
SVOboy 04-30-2006 10:16 AM
It's prolly just pump error.
It's prolly just pump error. The fact that you had to make it click several times to do anything suggests that something was up with it.
GasSavers_Danno 04-30-2006 10:38 AM
Oh ok, that it didnt put
Oh ok, that it didnt put enough fuel in. Crap, well looks like ill have to refill after a few miles again monday so that i can run a full tank and have it be completely accurate.
Matt Timion 04-30-2006 10:42 AM
Re: Oh ok, that it didnt put
It's possible that it put enough fuel in. The problem exists when you try to fill too little fuel.
For example, I could drive for 10 miles and then go to fill up. It would barely put anything in, which would give me a MUCH higher MPG than I am used to.
This is why I say to only count it if it is more than 5 gallons, as the law of averages usually leans more towards the actual MPG number.
GasSavers_Danno 04-30-2006 11:02 AM
cool. thanks
cool. thanks :)
Compaq888 04-30-2006 11:03 AM
anything less than 5 gallons is bull****. That is why I erased all my 150 mile and below fill ups.
GasSavers_Danno 04-30-2006 11:38 AM
ill erase it from my gaslogs
ill erase it from my gaslogs when my mpg goes up :P just so I can feel better :D
Compaq888 04-30-2006 11:47 AM
Re: ill erase it from my gaslogs
FYI I had the same MPG as you, even better. If I erase my racing tank I'll go into 29mpg. I haven't been really trying to get my mpg up like the rest of the people. If I really wanted I'd be in the 30's now.
