How to import/enter older records?
I want to import older records, even though I have entered newer records already.
I have a classic car with 15 years of records. Unfortunately, I didn't enter them for a while, and I would like to catch up old records. I would likely type them into my spreadsheet (predating app) and then want to merge into aCar. Is there a way other than: export as CSV -- delete from app -- merge in spreadsheet -- CSV -- reimport? If not, may I suggest a setting that turns off the limitation for only newer records? If you wanted to minimize accidental usage, put a checkbox in Settings that automatically resets after some time or reboot (and states such) Thank you as a longtime aCar user! William 1967 VW Karmann Ghia |
If the old records are in a CSV file, you should be able to import in the Import/Export menu.
If you have trouble, please send a copy of your fully backup and the CSV with the old data to support@fuelly.com and we'll see what we can do to help. |
