Suggestion: Tank range stats
Hi,
Not sure if this is the correct forum area for suggestions and daresay this has come up before, but it would seem relatively straightforward* and helpful to present a graph of recorded tank range for each vehicle type. It is great to see the distribution of fuel economy per vehicle, something similar for tank range would also be informative. Possibly even maximum recorded per user/vehicle if it worked better. Thanks * could well be wrong! |
Hi. You can display "average miles per fuel up" in your mini stats on your dashboard, which will show on other users profiles if you visit thier dashboard too. Ranking them wouldn't work, I've seen people with several thousand miles per tank where they have been saving fuel ups for a while and adding them in one go.
Note, My previous car averaged 700+ miles per tank, this one struggles with half that! |
I don't see that being a problem, the vast majority don't seem to add multiple fill ups in one go and a histogram would make it obvious that it was an outlier.
It would certainly be interesting to see the typical range of any given vehicle type at a glance. A 'tank range' version of this would be fine: 2012 Honda CBR250R MPG - Actual MPG from 275 2012 Honda CBR250R owners |
