-   -   Need help from the electronics guys (https://www.fuelly.com/forums/f22/need-help-from-the-electronics-guys-1837.html)
Matt Timion 03-26-2006 11:08 AM
I know that there are a number of electronics guys here, so I'm going to be asking for your help.
Provided I obtain all of the correct schematics and technical information, I want to build a conversion box that will convert the digital signal from a Honda digital VSS (vehicle speed sensor) from a 1992 carto the appropriate digital signal for the honda s2000 cluster.
It is my understanding that the 1992 Civic VSS is analog pulses, and the s2000 cluster is a digital signal.
There will also have to be something made that will convert the temp gauge, which I also understand doesn't work.
Another possible solution is to convert the display to run off of an aftermarket digital speedometer, which would be a viable solution assuming we could get the odometer to work as well. This may actually be the easiest solution to do. I'm sure there are some cheap aftermarket digital speedos out there to use.
Anyway, here a picture of the s2000 cluster in a CRX:
https://www.marklamond.co.uk/projects...installed1.jpg
Compaq888 03-26-2006 12:50 PM
didn't we go over this
didn't we go over this already??
When I used to have my msd system I hooked it up to the negative side of my coil and got the signal from there. Then the MSD sent the signal a tach adapter and my tech worked after that. That might be one way of doing it.
SVOboy 03-26-2006 01:04 PM
The problem isn't the tach,
The problem isn't the tach, it's the vss.
Compaq888 03-26-2006 01:17 PM
I know it's not. I'm saying
I know it's not. I'm saying the MSD might convert the signal so his new tach might work.
SVOboy 03-26-2006 01:18 PM
What function of msd deals
What function of msd deals with vss? (I've never used it)
Compaq888 03-26-2006 03:05 PM
Re: What function of msd deals
I dunno, I just had the idea that maybe a MSD box might convert the signal right. obviously the msd box uses a different signal that is why some cars can't use their oem tach with it. With a tach adapter I was able to use my stock tech.
SVOboy 03-26-2006 03:17 PM
800 ? 800: true);
https://images5.theimagehosting.com/s2k1.th.gif
https://images5.theimagehosting.com/s2k2.th.gif
https://images5.theimagehosting.com/s2k3.th.gif
Matt Timion 03-26-2006 03:32 PM
w00t. Thanks SVOBoy. I
w00t. Thanks SVOBoy. I need to print these out and make myself a small conversion harness for the display.
SVOboy 03-26-2006 03:36 PM
Can't do that!
Can't do that!
