Do you have/ use cruise control
My car has cruise control but i rarely use it. There are roller hills on the freeway when i live (~100ft) and the cruise dosen't seem to work well in this enviroment.
I would use it if I had miles of flat/ semi-flat highway. |
I will be joining the world
I will be joining the world of Cruise Control sometime soon. My car did not come with it installed, but I'm planning on putting it in in a little while here.
Mine did not come with it,
Mine did not come with it, but I am trying to install what is more appropriately called a throttle control. All I want is something to hold throttle position, not maintain speed. I bought a cruise control servo motor on ebay but have not figured out to connect to the throttle. Once that is done I just need to apply current to the servo clutch solenoid and it will lock the throttle position in place. The wiring will also have to include the clutch and brake switches so that the throttle will be released when braking or pressing the clutch pedal.
Something I will get around to some day I guess. No hurry right now. |
Re: Mine did not come with it,
Just food for thought. |
Quote:Mine did not come with
Re: Quote:Mine did not come with
Quote:All I want is
Quote:you know what? THat's
Re: Quote:you know what? THat's
I just took a look at the EX TB wheel and I didn't get it. It spins the opposite direction and can't be used for cruise control.
Lemme look at mine and see.
