All messed up
Hi
had an issue where i did a partial fill up and have since done two full tank fills since, but still my mpg didnt work. To try and fix manuall i deleted the two previous fill ups and added the miles and fuel added together as if it were one big fill up, then added the most recent fill up today. Seems everything so far for the previous fill up is fine, but the new one thinks the difference between 88615 and 88938 is 10 miles and as a result it thinks ive done 1.3 MPG can you help? |
bengillam,
I saw your post on Twitter this morning and responded to you a little while ago. The issue is with May 7th's Odometer entry (and I show you actually have a duplicate there as well). The mileage must've been typed incorrectly as it doesn't fit the mileage surrounding that date, and it's only 10 miles difference from today's entry. |
thanks, that may 7 is what i added this morning from my phone but seems to have processed it on wrong date, all the miles and litres are same. thanks will see if i can shift the date
ok after shifting the fuel with wrong date its sorted itself out, not sure quite how that happened as i just opened the web app on my phone and added litres, price and odometer didnt touch date :/
Fixed now, thanks |
Glad you got it fixed!
