Import of data into Gas Cubby
I've played with both side now and am hurting a bit after switching over to fuelly due to losing maintenance tracking. I normally need an oil change a month due to driving volume (have to love Southern California).
I have my last backup export from gas cubby before switching over to fuelly. It was corrupted during a backup (ended up with triple data and data not matching both vehicles). Is there any way to import into gas cubby and just continue using it (I've used it since 2008) until the complete transition? Offline access is also an issue as I'm sometimes in areas with bad coverage. Thanks in advance, Troy |
Bueller? Bueller? Bueller?
I'm not aware of GasCubby currently supporting an Import feature.
I'll research more into this and get back to you. |
