-   -   How do I measure gas in my n600? (https://www.fuelly.com/forums/f8/how-do-i-measure-gas-in-my-n600-1631.html)
Matt Timion 01-19-2006 01:43 PM
On my Honda n600 the gas inlet is so small that the gas nozzle will not fit correctly. This means it will not automatically shut off when the tank is full.
So it's going to be more than difficult to accurately measure MPG in this car.
The last time I filled up it actually overflowed out of the car.
Any suggestions?
(BTW, it has like a 5-6 gallon tank).
n0rt0npr0 01-19-2006 02:12 PM
lol
dude where I live all the gas pumps do that on my car lol
anyway
What if you just listen to the changing tone of the fill as it creeps up the filler neck?
Otherwise you should remove that filler neck and modify it so that the nozzle is able to enter deeper. I'd mod it so it burys it all the way to the handle. All pump handle (nozzles) have a shut off sensor in them when they detect a pool of gas. If you fill up slowly you may just be able to get it to shut off gently like I do it...I have to cuz these stations here are sooo ghetto
SVOboy 01-19-2006 02:23 PM
Bring red tanks of gas and
Bring red tanks of gas and some sort of filling stick, or something like that, I dunno.
rh77 01-19-2006 03:35 PM
Re: Bring red tanks of gas and
That's what I'm thinking -- you may have to fill a separate container of some kind and use that to fill up, but spillage may be inevitable. Accurate fill ups may have to suffer unless you replace the filler tube with a straighter one (not sure if that's an option).
RH77
