-   For Sale (https://www.fuelly.com/forums/f24/)
-   -   1992 Honda VX FOR SALE (https://www.fuelly.com/forums/f24/1992-honda-vx-for-sale-14681.html)
VXman 04-24-2013 04:45 PM
FOR SALE: 1992 Honda Civic VX! Best MPG at 58! The car has 210k, does not burn oil and has great compression. I have done a lot of work to this car. Besides all the repair work I also installed a 6 point roll cage and installed a cable to the ECU to watch the O2 sensor or lean mode. I also modified the original interior to fit around the cage. Below is a list of everything I did to the car and what it still needs. With all the repairs I used only quality parts, most from Japan.
The car is located in northeastern Ohio. The reason for the sale is that I have moved to Montana and opened my own repair shop. I just don't have the time to make it back to Ohio and bring it back here. I hate to see it go, it took me months to come to the conclusion to sale.
Mods:
6 Point Roll Cage with removable center bar with original interior to fit around the cage
O2 sensor cable from ECU to watch voltage
Repairs
Rebuilt transmission with all Japanese bearings
Timing belt, water pump, cam and crank seal. ( Asian water pump, Contec timing belt )
Value cover gasket with value adjustment ( Fel-Pro )
O2 sensor ( NTK )
Rust repaired and heavy undercoat on important spots
New battery
Fresh coolant with distilled water
New plugs and wires ( Denso )
New clutch
Fresh Synthetic oil ( Mobil 1 )
Bad:
V-tec solenoid leaks oil
I am looking for the best offer right now. So I just throw it out there even if you don't want to buy it please let me know what you think it may be worth. I really do want to sale it and am trying on here first then I will be putting it on Ebay. Also, I have a extra low mile engine to go with it, the engine has about 110k. Thank you for looking and your options. If you have any questions please ask.
Pictures can be seen at HondaVX Photos by Subaruguy | Photobucket
cascanjep 04-24-2013 05:02 PM
where in ohio are you located?? columbus??
VXman 04-24-2013 06:46 PM
About 45 min north of Yougstown near the lake
cascanjep 04-27-2013 08:58 PM
what are trying to get out of it
VXman 04-28-2013 07:40 AM
I am looking for the best offer. I have a lot of time and money into it. Make me a offer of what it is worth to you.
