1994 Civic VX - doesn't start, help please!!!
1994 Civic VX - car sometimes doesn't start/sometimes very difficult to start, sometimes starts ok and runs ok, at low RPM engine doesn't make any power, could barely get the car moving, idles Ok.
Symptoms started when the car overheated back in the summer after one of the radiator hoses failed. I was out of town and had to drive about 5 miles to the closest parts store to get a new hose. After replacing the hose the engine would occasionally run very rough when accelerating at lower rpm (1500-2500) - thought I blew head gasket, but the symptoms went away and it started driving ok. I noticed that the distributor was making squeaky noises - replaced the distributor and the squeaky noise went away. Since that incident, I've been driving the car and put about 4k miles and been getting intermittent rough running while accelerating at lower rpms, sometimes a week would go by with no problems. Now the problem got worse, and occasionally the car would not start at all. I just finished replacing the timing belt since it was time anyways and thought that may be it would help, but it did not help. Also just replaced spark plugs, fuel filter, air filter. Checked engine compression 200/200/190/200 psi. Did leak down test - did not show any problems. Checked timing and spark - fine. I'm puzzled. Right now the car is extremely difficult to start unless I let it sit for a day. Any ideas on how to go from here? |
Re: 1994 Civic VX - doesn't start, help please!!!
Can we assume that by "difficult to start" you mean that it cranks ok but doesn't fire?
Have you eliminated fuel supply as an issue by spraying starting fluid into the throttle body to see if it fires? |
No check engine light? Any stored codes? Can you hear the fuel pump prime for a few seconds when you first turn on the key?
Perhaps the MAP or some other sensor got wet back when the rad hose failed. |
I was thinking fuel delivery too. If spraying while cranking helps, I'd vote for fuel pressure regulator (FPR). You don't by any chance have a fuel pressure gauge do you?
FPR failure could give the symptoms you describe, I think. Although it is more common to get an excessively rich condition rather than not enough fuel. If so, it probably wasn't from the overheat, it was probably coincidental. Another thought is to eliminate simple stuff first. Bad gas?/Wet fuel? B |
So today after it would not start: * checked spark on all four cylinders - there is spark * sprayed starter fluid while cranking - would not run but did backfire, shooting cool yellow flames out of throttle body :) I'll hook it up to fuel pressure gauge and check fuel pressure next. Would love to hear any other ideas, cause I want to get this thing fixed :) |
Spark timing is probably the next suspect. Distributor gear slipping when warm? Distributor cap loose when warm?
I forget what they call the electromagnet sensor bits inside the dizzy.... ignitor? maybe.... anyway, that could fail when warm but work okay cold, or just randomly not work right.... I would assume there'd be a check engine code, but maybe not.
Did you replace your distributor with a new one or a junkyard one? Do you still have the old "squeeky" one? I'd pop the old one back in if so to see if the problem stays or not. I didn't see anything in your posts about replacing plug wires recently.... Open the hood in the dark and have someone crank it/idle it. Spray the wires with a mist bottle (like you'd have windex in) with water. Any arching means replace em'. B |
Put a timing light on it and check the timing while it is cranking. Make sure strobe flash is regular.
Check all of the wire connectors and especially all of the grounds under the hood. |
