Modifying exhaust to increase mileage?
Will modifying the exhaust pipe yield better gas mileage? Some people have said that putting on a larger pipe will in fact help with fuel economy, as the exhaust is less restircted.
There is a Civic EX at my local junkyard with a dual point exhaust. it should bolt right up to my car. Do you think that switching from single point to dual point will help increase my gas mileage at all? |
Help! 87 Honda Civic A/C Wiring
There was a thread about this not too long ago over at honda-acura.net that talks about exhaust diameter and performance (or efficiency in our case). Conceptually it's easy to see why a larger diameter pipe would allow more exhaust flow. However, there is a practical limit in this. The details are in the article I referred to, but the basic idea is that it's about balancing cross sectional area with velocity. An exhaust pulse traveling down a pipe will go faster than an identical pulse going down a larger diameter pipe.
I just searched for the thread because I think it might be a worthwhile read everyone here. <a href="https://www.honda-acura.net/forums/showthread.php?t=201281">Backpressure: The myth and why it's wrong</a> |
Vertical Range of Electric Vehicles?
PS: any luck on the knuckles? |
Sometimes being a fuel economy dork is the coolest thing
I have always been told that back pressure is good at low RPM's. It seems to help torque.
Nissan has a muffler on the 2.5 L cars with a spring loaded valve. At low RPM the valve is closed. As pressure increases (at higher RPM) the valve opens increasing flow. Best of both worlds. |
Jet turbine exhaust
Here is a link for a jet engine car exhaust:
https://www.aero-turbine.com/how/ Anybody know how to add an afterburner? |
Re: I have always been told that
I'm not sure how effective
I'm not sure how effective it is but I hear that you can weld a sparkplug into the exhaust tip and plumb in some propane with the appropriate controls and flip a switch while tou're gunning the engine to shoot flames out the tailpipe.
Re: Modifying exhaust to increase mileage?
I'm trying to look at the design of fuel-efficient Hondas for direction. It seems like the more restrictive, the better. Since the EX had a more powerful engine, I'm guessing that it has a larger exhaust system. My gut feeling is that it would yield less torque and a loss in economy. This is all just thinking out-loud, but if you lose torque, you press on the throttle more to get going from a stop, which means more fuel used. Once out on the highway, free-flow may mean better economy since the RPMs are up and it would take less energy to push the exhaust out -- but for some reason, you need backpressure at lower RPMs. If I had to decide right now, I'd go with smaller diameter piping and a stock muffler, or one with a valve like the 2.5 Altima or Lancer Evo. A device called the "Turbolator" is on the market that does the same thing (separate thread). I'd really like to understand the science of backpressure better... RH77 |
You may want to just visit a
You may want to just visit a local muffler shop and ask them what the correct pipe size is for various cars. I'm certain they have this information on hand.
I think that the stock pipe
I think that the stock pipe diameter on most cars is the best. If it's possible you can install maderall bent pipe for a tiny increse in mpg.
The turbolator (sping valve exaust tip) looks interesting. I think it would help at idle. |
