Gearz 6 tips to increase fuel economy
Saw an episode of Gearz today offering 6 mechanical tips for better fuel economy for late model vehicles? I'm not a gearhead. What do you think would work best for a 2003 tundra, if any, and what percent increase could be expected.
1. increase intake air flow by replacing air filter. They didn't distinguish between warm air intake vs cold air intake. I've read about warm air intake is definately the way to go for fuel economy. 2. Computer programming. They suggest recalibrating vehicle's timing/shifting. 3. Spark Plugs. Replace spark plugs with mult-tipped plug that suppose to burn fuel more completely. 4. Exhaust. open exhaust to increase air flow with cat-back system and beter yet, high-flow cat and even headers. 5. Synthetic Oils. replace oils with synthetic 6. SVO. related to converting diesel to run on SVO. thanks |
my personal opinion of most of those modifications is that you will probably never see enough gas savings out of the results to offset the initial cost of the modification.
most less restrictive intakes or exhaust systems are pretty expensive. changing an air filter is relatively cheap but to replace it with a freer flowing intake usually runs ~$200 or more. exhaust is basically the same concept only more expensive. the computer programming (unless you know someone) can get expensive fast. I was looking at reflashing my truck after a cam change and they wanted $500 for the computer reflash alone. the SVO or WVO can have a huge initial cost as you have to change over your vehicle with tanks and also safeties to purge the lines before it shuts off. you also have to have space to store it and a filtration system along with a steady flow of french fry grease (or whatever). my brother in law spent right at $5k switching over his f250 and sold it about a year later. I have heard that the DIY ones are a lot cheaper. I can't comment on the synthetic oils or spark plugs as some people have cliamed to see gains and others have not. |
Those two guys covered what I would have said. I'll add this: The EPA has tested and found that even a severely clogged air filter will not increase fuel usage. There is a link in my meta-sig about it. However, if you are a hypermiler who tries to use an open throttle to reduce pumping losses (lay on the gas pedal and shift at low RPM), some of your effort will be negated by the low-flow air filter.
If you want to run fresh clean SVO, it will never pay for itself. If you want to run WVO and think you can do everything you'll need to, that would definitely be a great idea. I'd love to do it some day. I don't think it's practical for, well, anyone. |
Larry,
There is a list of 201 tips at the top of the page , many of which focus on the more basic and straightforward aspects of fuel consumption like tyre pressures and weight. Well worth a look. Pete. |
The best thing to do on that list (MPG wise) would be to switch to a synthetic oil.
Also, if you can drive the Hummer less that would be good too. |
one thing I did that truly doubled my mileage but cost me $2000....
(doesn't this sound like a sales pitch) park the truck and buy a beater. |
I don't agree that switching to synthetic would cause a significant gain in fuel economy. It would certainly never pay for itself in gas saved. As Jay suggested, if your oil change interval increases, then it could pay for itself.
that is my reason for using synthetic mainly to keep my engine happy, mpg gains probably exist but ive heard theyre 1mpg which means 0mpg or .5 mpg or 2mpg which is meaningless |
Gentlemen, I thought this was GASsavers.com, not MONEYsavers.com. I truely appreciate each and every response (from people that i view as experts), but nothing is more discouraging than getting an opinion that essentially says it's not worth saving gas if it doesn't save you money. My goal is to reduce my fuel consumption and if that costs me some extra money that I can afford, then I might just decide to do it. Please gentlemen, please, give us a response as it relates to saving gas and then you can add comments about how cost effective a particular technique might, or might not be. Costs certainly have to part of the equation, but please don't dismiss a technique or technology simply because capital costs might not be recovered. Several 1-mpg saving tips might just add up to a significant savings.
I bought a beater VX nearly a year ago and parked my truck as much as possible, but i still have to drive the truck 50% of the miles. I've done the math; reduced my consumption by 30% and now I'm looking to reduce my consumption when I have to drive the truck. Thanks. |
