Solar Battery Maintainer
would this be a practical tool to help w/ EOC?...
https://www.northerntool.com/stores/a...ine&market=ORL it's on page 4 at the bottom. sorry, i couldn't get a direct link. i quit EOC, due to battery issues, except ending a trip, so... |
It's a battery maintainer not a charger. It replaces the power lost by just sitting. I have one of those I put on my lawn tractor when I don't use it for a while. I think it helps?
i could try it w/out wasting too much $$$. we have a car that sits for long periods of time anyway. getting out the charger every time bites. |
It sounds like your battery is old and worn out.
For EOC, I don't see that item making much difference, especially if you have a new battery. I doubt that it would take more than a few seconds to return the same amount of power to the battery that a 1.8 watt solar charger would put in in an hour. For maintaining the battery on a car that sits for a long time between uses, however, it sounds like a great idea.
The biggest killer of batteries is overcharging.
I see motorhomes and power boats with bad batteries all the time. The lead acid batteries are all bowed on the sides which is a sign of constant charging. That being said, a battery maintainer should keep the voltage from going above a certain value. If this product does that and you keep the solar charger connected 24/7, then yes this is a worthwhile investment. |
