Fuelly Mobile Shortcut on iPhone 5 not full screen.
I have noticed that when I use the Fuelly Mobile site via a homescreen shortcut on my iPhone 5 it loads in a boxed screen, like other apps do, that are not optomized for the iPhone 5.
I have saved a couple links to other mobile sites and they all seem to load as full screen links. However the Fuelly site does load without the navigation bars on the top or the bottom. Is there something in the html that does this? Can it be tweaked to open full screen with the iPhone 5? I know it's a trivial thing, but hey the extra space is there. If you'd like I can post a screen shot if my explanation doesn't make sense lol. |
Wow, weird. I see the same thing, I deleted the shortcut, went to m.fuelly.com and saw it loaded in the entire window, set a new home screen shortcut, and blammo back to letterboxed smaller window.
This kind of makes no sense, we'll look into our end but I think this might be a iOS bug? |
Yeah, it was a bug with the apple-mobile-web-app-capable mode. I removed that so it should be set to go.
You'll need to remove your home screen Fuelly icon and re-add, unfortunately. But it should work fine after that. |
That worked!
Thanks! |
It's now full screen, but now it just launches in Safari instead of like a web app.
Yeah, that's the trade-off we had to make. Once Apple fixes this problem we can go back to the other way if that works better.
