Totally pointless- adding power and efficency to a 66cc chinese bicycle moped...
OK, so I have a partially finished bicycle moped (one of those 66cc happy time motors) in my garage. Engine is attached, not much else.
So, mostly for fun, I want to add power and efficiency to this thing. Currently I am working on placing the carb/ air intake off to the side to get cold air (and because my frame is too small for it to fit normally. I was reading about a "wicking" carburetor in the experements section from what I gathered it basically consisted of a metal box with holes in either side of it, a pool of gasoline, and special oil clean up rags hung from it to wick the fuel up and have it evaporate into the air. Reading this, it looked simple enough, I just have a few questions: 1. On an air cooled engine, would this overheat it? I assume this would create a lean burn that would make it burn hotter. 2. how well does 2 stroke engine oil evaporate? would I be getting the proper amount of oil to my engine? 3. I know this would help eficenct, but would it hurt power? I only have 2-3 horsepower, so this is a biggy. Other things I'm considering: -smooth, not knobby tires. -Water/Methanol Injection to help reduce engine heat -small fan, battery powered, next to the engine, to cool it faster (or just build arger fins) -Nitrous. I'm a 19 year old guy...who dosn't want nitrous? Another, sort of unrelated question. HHO- I know it's hard to get it right as an integrated system, but how difficult would it set up an electrolisis machine off power at home, hook it up to a compressor, and get a fitting to fill up a propane tank with HHO and adding it to the fuel mix? Also how would just adding strait propane, oxygen, or any other gas that can be bought in a small cylender effect efficency, power, and heat? P.S. I know that compressing your own HHO at home would be dangerous and crazy, and that adding a front hub motor and charging a battery at home would be much simpler and easier. |
Unfortunately 66cc is too small for any real performance improvements but what you could do is measure your head temperature and block off the air intake for the cooling of the engine to raise the engine temps. The hotter an internal combustion engine runs the more efficient it is to a point. I don't know how much you'll get out of it since I don't know what your engine normally runs. Normally they hover around 350 under load. Since it is a 2 stroke all you can do is get the spent fuel out of it as fast as possible. Exhaust is your only bet here. And finally, I don't think the wicking carb will work because 2 stroke oil doesn't evaporate. |
thank you. You just saved me an engine.
Now, there are some various expansion chamber exausts availible that are much better than the stock one. What about adding pure oxygen and adjusting it to run as richer mixture? This probably wont help with economy, but it should help with power. BTW, I wasn't expecting to do much with the 2 stroke. When I complete this I'm going to try getting a 4 stroke and massing with that. I'm hoping that by using very small engines I can take some more risks and try more exotic solutions that would be too costly on larger machines. |
FWIW, I've run a lot of nitrous in the past few decades. However I can only advise you that it is a COMPLETE waste of time and money for this project. Even if you can get a 50% power gain, do you really think that will be worth it? No way! Remember that your top speed won't go up, only your acceleration. And who really cares if you go 0 to 25 in one second less. It's been done, but mostly as a science project by someone with extra money to throw around.
I love HP (and torque) as much as the next guy, but you're wasting your time (and especially money) on that one. -Bob C. |
The old myth that road bikes use narrow tires for rolling resistance is wrong; they use narrow tires because they have less aerodynamic drag, a very important concern for road bicyclists. The higher pressure that they can handle mitigates the increased rolling resistance. |
Yes, I do know to get fat ones, I have a road bike as my main bike, and I have all too many scraped elbows and knees to know that skinny ties suck for cornering. Or for potholes. Or sand. Or water.
-BC |
ahhh...thanks for the info.
I'm still looking into ways to soup it up. it's a $125 engine, and I'm not afraid to experiment with it. I have some personal desire to get some first hand knowledge about experemental ways of souping up scooter engines, mainely the fact that you can park a 50cc (or something that looks like a 50cc) on the sidewalks in the city. |
I don't know if your engine is one of them, but they do make kits to go to 80cc from 50cc. I think it is just a big bore kit.
I think that's on one of the Yamaha scooters. All those "80cc" bicycle moped kits on ebay are actually 66cc, it's just that they are in the 60-80cc "class" that they get labled as such.
