newbie needs help
Need HELP!!! I built my first HHO generator using wire tower, mason jar, elbow, and adjustable irrigation valve. I use 1/2 tsp. of baking soda with distilled water. I hooked it up on my 2006 dodge dakota. When had it all out I tried measuring the flow but there was no hydrogen. What I did was use the water displacement method with a water bottle. I gave it power and it started to work but there were no bubbles flowing into the water bottle. I need to know what I may have done wrong if any one can help.
If hydrogen is able to escape other than out to your flow tester then you usually will not get a reading.
Make sure you are completely sealed. |
Seal anywhere the HHO could escape with silicon caulk.
alright was bench testing my generator last night and got good results. I took baking soda, vinegar, water, rubbing alcohol, and peroxide and mixed it together for a good winter electrolyte. Good results but did a little experimenting. Took 1/2 cup of drano and mixed with water. Very good results but after about 2 minutes running in the garage the wire started to glow red. I shut it down and saw the wire melting the plexiglass tower. I think I put too much drano in. Anyone have suggestion on how to do it.
Drano? Why?
And why vinegar, peroxide, and rubbing alcohol? |
i used drano for the sodium hydroxide and if you look on youtube there is a video for winter solution. I just thought I would experiment with it.
dont use all those chemicals together. Use the sodium hydroxide ( lye) and leave it at that. your wire was turning red because you used to much drano in the solution. the more you put in the more amps you will draw, so dilute the solution down until the wires are not getting hot any longer( slightly warm is ok but not real warm) you need a amp meter or at least a multi meter that will measure dc current. I can go on in more detail with other solutions but you will need to digest this first.
HHO System
Does anybody have a set of diagrams etc, to build a HHO system far a car.
https://www.panaceauniversity.org/Hydroxy%20Boosters.pdf https://hhoencyclopedia.net/hho/hho_success.html https://www.hhoknowhow.info/ |
newbie here.
here is a system i am working on, its been installed and tested but not sure of mileage gains yet. click here and watch the vids. https://www.searcypress.com/ JES |
