-   -   Can an exterior block be stealth? (https://www.fuelly.com/forums/f14/can-an-exterior-block-be-stealth-10103.html)
itjstagame 10-03-2008 05:02 AM
Ok, so the fiance's Lexus ES300 has a massive grill up top and then a giant one below the bumper. No idea why really, yeah it's a V6, but the radiator is bigger than the one in my pickup!
Anyway with it being so cold it definately doesn't need all that grill.
Ok, so I can't do a stealth mod from behind: https://www.christopherjwerner.com/images/CIMG0509.jpg
This car has a crazy body pan, it's almost impossible to change the oil filter or anything else from under the car for that matter. But then if that's what helps it get 33MPG@65MPH with a 3L V6 at 3500+lbs then I'm ok with that.
Anyway, so we have to go from the outside, so the other day I cut a piece of coroplast to fit (the grill part is actually recessed a bit in the bumper), sprayed it black and ziptied it at diagnols. I even patterned the zip ties :p .
https://www.christopherjwerner.com/images/CIMG0508.jpg
Anyway I think it looks pretty good, it's recessed flush with the bumper and doesn't look too obvious, there was just a black grill there before anyway. The trick will be if the fiance notices because I'm sure I'll catch hell for it if she does.
https://www.christopherjwerner.com/images/CIMG0510.jpg
I think should be fine for winter, probably for summer too except she likes to idle for hours with the AC on :rolleyes: . So we'll see. I also found out it's 3 bolts to remove the part of ducting that draws intake air from up and over the radiator (you can see it in the last picture just over the right horn). After removing this its should draw from in behind the radiator instead. I'm also curious if this will even help any, with the belly pan it has and all that grill openning, it must have air movement in mind and be piping it out the bottom behind the tranny or something and it's probably in some way it's not disturbing air too much, who knows.
Jay2TheRescue 10-03-2008 05:13 AM
Have you seen what Phillip did with his Saturn?
https://www.gassavers.org/garage_imag...jpv18lbnze.jpg
He even put a Saturn badge on it. Looks very stock. Other members have used plexiglass to do a block from the front. Smoke colored plexi might even come off as a style enhancment on some cars.
itjstagame 10-03-2008 05:55 AM
Hmm, what was stuck to the bumper, deer whistles?
Yeah looks nice, the screws look good too. Too bad we can't put something inbetween the layers of coroplast, like spring tabs of a normal grill so it's completely hidden.
itjstagame 10-03-2008 05:58 AM
I'm hoping this tank is a bit better since I was driving it more. I need all 3 to be Hpyermiler.
theholycow 10-03-2008 07:10 AM
:confused: Coroplast is really easy to do with hidden fasteners. It's hollow with a million little channels running through it, and the surface is strong.
You can get one of those wire H-frames that's used for sticking a coroplast sign in the ground and break the wires apart. At that point, you can do many things with the wire:
- You could have the wire stick out the ends and into holes drilled in the car
- You could bend it 90? and stick it in the end, and just cut back the rear surface a little bit so the wire doesn't show past the front surface, then the wire can be bent around the existing grille (or rolled into an eyelet for a screw/washer, etc)
- You could bend it 90? and cut a hole in the rear surface closer to center and ease it in, then attach to the car as described above
- You could conceivably even feed it in the end, break it through the rear after a couple inches, then break it back in to the rear a couple inches before the other end
You can glue coroplast. You could even use zip-ties threaded through the channels.
GasSavers_BEEF 10-03-2008 09:23 AM
I think I did pretty good with my grill block. the pic in my garage shows what it looks like. even I will admit that the pic makes it look better than it actually does. it is pretty smoothe and from about 10 feet away, it looks like it is supposed to be there. up close, not so much.
not too good with the posting of pics so, if curious, check my garge out. (or if someone would be so kind to post it for me). I used plexi-glass and double sided tape along with some white paint and kitchen caulk. redneck?...yes, but if I had not have told you, you might think it was supposed to be that way.
I also did my wifes element but I have been told that it reflects in the sunlight so I guess it isn't too stealthy
theholycow 10-03-2008 09:46 AM
Originally Posted by BEEF (Post 120326)
(or if someone would be so kind to post it for me). I used plexi-glass and double sided tape along with some white paint and kitchen caulk. redneck?...yes, but [...]
Silicone might last longer than common kitchen caulk. Anyway, here's your embedded pictures...
https://www.gassavers.org/garage_imag...nzmualc74a.jpg
https://www.gassavers.org/garage_imag...v9bt301mq9.jpg
https://www.gassavers.org/garage_imag...mrix3jsywv.jpg
https://www.gassavers.org/garage_imag...xvjmsyi0y7.jpg
Jay2TheRescue 10-03-2008 10:12 AM
Looks like its supposed to be that way.
GasSavers_BEEF 10-03-2008 07:39 PM
holycow,
thanks for posting the pics. I was trying to think of a way to flush it in with the body and the caulk was already white (definite advantages to a white car).
jay,
I have always thought that modifications should look good. I admire that some people use cardboard for experimentation but once you know you want something permanent, I think you should make it permanent.
to each his own though. If my car wasn't white, I would have checked into some of the duplicolor paint at autozone (or similar auto parts store)
theholycow 10-04-2008 03:54 AM
:thumbup: I didn't realize that you just used it to fill gaps. It's perfect for that. I thought you used it as adhesive.
