On the heat issue, I'm ready to accept that it does what you say it does, but I'd have to understand how it does that. As I understand, heat cannot itself turn a turbine; it can expand a previously cool gas, which in something like an exhaust system would increase the gas's velocity and pressure, which would certainly turn a turbine. However, in an exhaust system, the exhaust gas is hottest when it comes out of the cylinder*, so it's not going to pressurize any more than it already has between the piston and the turbo. *: And maybe again when it comes out of the catalytic converter, but that's not relevant here. |
i'm not convinced heat yields a measurable amount of increase either. the "new" thing in twin turbos is at the tail pipes--force space constraints as well, obviously. measurably cool by that time?
also, my new turbo Mack truck https://www.gassavers.org/garage/view/969 often keeps the engine running(key off) to cool the turbo before shutdown. the truck is very fast cold or hot(relatively speaking), it doesn't matter. my speculation is based on experience and suspicion only--no facts or sources. |
Quote from Borg Warner Turbo Manufacturer The turbocharger turbine, which consists of a turbine wheel and a turbine housing, converts the engine exhaust gas into mechanical energy to drive the compressor. The gas, which is restricted by the turbine's flow cross-sectional area, results in a pressure and temperature drop between the inlet and outlet. This pressure drop is converted by the turbine into kinetic energy to drive the turbine wheel. The turbine performance increases as the pressure drop between the inlet and outlet increases, i.e. when more exhaust gas is dammed upstream of the turbine as a result of a higher engine speed, or in the case of an exhaust gas temperature rise due to higher exhaust gas energy. |
The turbo companies do want the turbo close to the exhaust valve to utilize the heat. Today's turbo's have made major advancements just in the last 10 years. Turbo lag has become a thing of the past with the correct sizing. Turbo Technology has come a long way.;) |
So far, that gets us to where it is using exhaust energy to shove more air (and therefore fuel) into the engine, reducing pumping loss on the intake but increasing it on the exhaust. At most, if it was a 100% efficient machine, it would seem to come out even. Erik's explanation makes more sense to me, though. |
I will also be building a third engine this winter with stock piston to cylinder clearances and stock ring gaps. If anything I have become very good at switching engines out.;) I can have a engine and transmission pulled and another one up and running in 50 minutes.:D |
I wish I had that level of skill and experience.
Here is what the car looks like as of today. I'm getting the body work already and hopefully I should have it painted by the end of this month so I can get back to testing. https://www.fuelly.com/attachments/fo...b4daf447fc.jpg https://www.fuelly.com/attachments/fo...3754d8853c.jpg |
