In recent years they have designed the caliper seals to provide some retracting force on the pads so the drag is reduced. Absolutely have the rotors turned to minimize drag. I have seen replacement rotors that were warped 20 thou. We turned them whether they were new or reused.
regards Gary |
Really? That's great. I wonder if there are any that we could retrofit to our brakes.
Drum brakes up front is really unsafe. Drum brakes suck, they only persist because they're cheaper to manufacture. But they can fill up with water. They easily overheat. They're overly complicated. Nobody here wants to trade safety for mileage. Disc brake rotors supposedly "beat back" the pads. But yes it is true that they drag some especially on older calipers. Honda doesn't make the best brakes in the world, but they're also not the worst. I'm pretty sure the OP could have saved some grief if he had found a "B18C into a VX" swap guide and worked backward. They convert the 5 wire O2 to 4 wire. There is nothing to fear from "15 year old wiring". The wiring itself should be as good as it was when new. Sure, the tape is dry and cracked in places... |
Sorry I couldn't resist.... |
Wow, I haven't been back in a while and there are a handful of replies. Hey guys, can you take a picture of your new O2 connectors?
Gary |
I wanted to post my extrodinarily easy and positive experience converting a 1992 Civic VX California emissions to a 49 state Federal lean burn version.
As posted elsewhere, many (all?) 1992 CA Civic VX's came with the 5 wire o2 sensor installed and that included mine, so nothing to do there. The only thing I had to do was to unplug the exisiting CA ecu and replaced it with a used 49 state ecu that I purchased. Done, perfect, immediately have a fed version lean burn mode Civic VX. This will go down as one of the easiest modifications with a big impact that I have ever done. Just so you guys now that this swap out can be stunningly easy to accomplish given certain senarios. |
Re: lca13's 93 California VX Thread
IM glad to be part of this forum and love my vx.... im in the bay area california and would love to do this hopefully easy swap out can anyone help me?
