-   -   Have you had results with acetone. (https://www.fuelly.com/forums/f8/have-you-had-results-with-acetone-2761.html)
8307c4 05-16-2008 08:00 AM
Originally Posted by JanGeo (Post 95017)
Check your math . . . it adds 2.344 cents per gallon . . . 23.44 cents per TEN gallons! Now it is not so bad HUH? Takes about a 1% mileage improvement to break even.
And driving 80 MPH without Acetone would produce a lower mileage but there is no place to drive that fast around here. THere are some xB owners that do drive that fast and get in the high TEENS for MPG.
You are correct I did mess that up, but now a gallon of acetone is $16 :p
So almost 4 cents a gallon, 1% yeah...
All right but the more folks dump acetone in the tank the higher acetone goes.
We just don't have a million barrels of acetone a day to go around.
90accord 05-20-2008 02:03 PM
I have a 1990 accord ex 4 dr w/5spd tranny with no 3rd gear (its gone!!!). The best mpg I could get was 25 mpg with mix driving. That's open Freeway in the morning and traffic in the afternoon going home from work. I drive 55-60 in the mornings and in traffic (stop and go) in afternoons. 2 days after I added a 3oz acetone/10 gal. Gas mix I got a wooping 29.17 mpg. My gas cost went from $9.19 a day to $6.83 a day. I celebrated and bought me a 16oz beer to drink at home!!! that's the price differance I save a day now!!! Thanks yall!!!
Max
bkrell 05-20-2008 02:52 PM
Over at bitog we've had a lot of people try acetone in various ratios at least as far back as the Katrina aftermath. I can think of ONE person who's seen any sustained increase in FE.
Big Dave 05-20-2008 04:18 PM
Snake oil man, snake oil.
I tried a couple of quarts of it 2, 3, and 4 oz to 10 gallons and...nothing.
Like two-stroke oil, acetone is just wishful thinking.
12% improvement? I'm calling BS on that.
bkrell 05-20-2008 04:50 PM
I've never heard of people using 2 stroke for FE, just upper cylinder lubricity.... But I don't doubt people trying it.....
GasSavers_RoadWarrior 05-28-2008 03:14 PM
Well the idea is that some sort of oil helps stop acetone or other solvents killing your fuel pump from lack of lubricity.
I've just stuck 2oz of Evinrude OMC low carbon TC-W3 and 5oz of acetone in my full tank for a retry. (15 gal tank)
I wasn't bothering because we are supposedly getting ethanol now, but last time I was at my fave gas station I looked all over the pumps and couldn't see the warning sticker, so thought I'd give it a go again. Used to be worth ~2mpg in marvin.
Doesn't so far seem to have got that same smoothness I remember before, but it's pulling up grades okay. Gonna try and remember to fill up before I do the weekend city thrashing.
bkrell 05-28-2008 06:14 PM
But GASOLINE is a solvent. What does it matter if you put acetone in? Many, if not most after market injector/fuel system cleaners have acetone or MEK in them.
JanGeo 05-28-2008 06:48 PM
The Torco GP-7 two stroke lube has PIB chemical that helps the gas burn better as well as provide some lubrication and only a very small amount is needed for it to be effective.
I just put my first 3 oz of Sally's Acetone in my xB after almost a gallon of Ace Acetone and have not driven much yet but I did see a record high mileage trip from Home to Office the other night.
GasSavers_RoadWarrior 05-31-2008 07:35 PM
Hmmm, inconclusive... matched my best tanks, which is ~5% higher than average. But, the gas I was running is from the "wrong" pump, the ones I always try to avoid, but couldn't due to it being busy, all my low tanks are off those pumps, and my high tanks are off the "good" pumps, so it could be as high as 10%, or it could be 0 as it's within normal variation.
