So what if you took a pot with 300 degrees of rotation moved it only 1/6 of the way to 50 degrees and stopped? In that case wouldn't a 30K pot work? The next trick is finding one of those ;) . https://www.elexp.com/srp_s30k.htm I know you can get a 50K pot at radio shack. 0 to 50 degrees would be 8.3K. Is that bad? Worth testing? Or wait for that $0.90 30K one :D |
Some ICE cars have instant heat too. I don't know about the US market cars, but the last generation Echo hatch that I test drove had a honking big resistor in the heating duct that you could light up as soon as you started the car. It didn't feel "hot", but warm air did come out of the vents within a few seconds. But man, the BTUs coming out of an ICE heater once warm is pretty hard to beat with ceramic heaters. Even the EV1 had a lousy heater, from first hand reports I've read. (Though it was a heat pump, not a ceramic resistor.) Efficiency, efficiency... |
The amount of time I've spent looking for a deal on the right pot, I could have just done some work and earned enough $ to buy several at list price. :D But it's the principle! (I even considered making my own wire-wound pot, but couldn't find any decent resistive wire around the workshop ;) ) |
I even took apart the Playstation analog controller to see what pots it has.
Kids, don't try this at home. :D |
Hmm: https://www.fsipcatalog.com/p-4053-mo...ntiometer.aspx
0-5k ohm, says an email from the vendor. Diagram shows 3-wires. It's a slide pot, but that doesn't really matter. Looks like it may also have microswitches built in. $14 plus shipping. https://www.fsipcatalog.com/images/Pr...m/MODEL810.jpg |
I was thinking that slide pots are notorious for getting dirty and flaking out, but after looking at it, I think that one may be pretty well sealed. :thumbup:
Well, I got some advice & encouragement from an experienced EVer...
Nice work Darin. :cool:
