Re: Yup, the kill-o-wat meter is
Re: chargelog. that's
You want to look into a freight service. DHL, FedEX, and UPS all offer freight services. It's cheaper to deliever to a business than residential when using freight. When the guy delievered my engine he was so relieved that I was actually home. I looked on the street and he was driving a GIANT truck. I swear it was a semi, but I can't remember. The engine was on a pallete, which it still sits on. This is why engines are so expensive to ship on ebay, but if you're willing to do it (and the buyer is as well) then I say you go for it. You also have two possible scenarios. You could part the engine out (sell the head, the pistons, etc.) which woudl make it much easier to ship. You could also just keep the engine as a spare for when your engine dies. OR, build a kick-*** go-kart. |
Quote:OR, build a kick-ass
Re: Quote:OR, build a kick-ass
A 700 lbs go-kart with a 90 HP engine. That was be so freaking cool. I bet it would get awesome gas mileage too. |
I'm surprised metro motors
I'm surprised metro motors even sell. I guess honda motors are so free because there're powerful replacements to them, *shrug*
Re: small town. no craigslist.
Good luck selling it. The thing I've learned is that sometimes you just have to have patience with these things. I'm still having people contact me for items I listed on other sites for sale last September. |
torch work
Heat the area up to be welded a little first then wire brush the undercoating off so you don't breath the fumes and start fires.
Curtis
Good deal on the curtis! Definately you should use it, control is important when using this kind of power and it will control the load put on your batteries better.
Puddy knife on the undercoat - the stuff is designed to stay on and not be easy to remove, maybe some compressed air from a long metal hose with a nozzle when it starts smoking and burning to blow it off. |
compressed air is a great
compressed air is a great idea for blowing out the flames. i noticed today a couple of times i got a mouth-full of fumes when i took in a good breath to blow out the fire.
the only thing about the curtis is i'm not sure what its amp limit is. it's probably kind of low. the controller that came with the forklift has a high rating - around 500A. but you're right - its design (SCR) is harder on batteries than the modern controller style. |
curtis
there should be a lot of info on the curtis online - check the model number - and you don't need a lot of amps if you uses the gear box.
Re: patched up some more holes
i've been using flux-coated
i've been using flux-coated brass rods. i've heard you can use coat hanger wire, but i haven't tried it. i'll give it a shot today and let you know what happens.
yup, coat hanger works, but
yup, coat hanger works, but its melting point is higher, so it's a bit harder to work (more of a chance i'll melt the car). also you'd need to add flux. but if you ever run out of brazing rods...
and the rods i'm using are bronze - i said brass by mistake. |
Great DIY
Wow, great DIY-ing. I guess if you haven't welded much before, you just have to try it, right? This is a great thread, BTW! Keep us posted...
Indeed, this gives me hope
Indeed, this gives me hope for my own welding experimentation. I might buy another CRX with my friend that needs hella work just to get practice in with fixing rust and painting and ****.
Mehbe we'll make it an EV while we're at it, :p |
drains
Make sure the drains work!! I may have to learn welding on my Geo to fix it - doesn't sound like my brother is going to be working on it much - would probably only take a few hours of welding now that it is in about the right position but he doesn't see it that way yet I work for hours on his computer making it run well. Why don't people see that balance of time for time....well anyway - anyone know of some alignment tricks to get things lined up properly on the Geo before I weld everything in place let me know!
Re: drains
the outboard drain is perfectly positioned to receive tire spray directly into it, and once the water (salty water in the winter) is inside, it's not going to dry up quickly. the inside floor, firewall, and underbody of the car form a roughly triangular shaped cavity accessed by those drain holes. Quote:
Re: Great DIY
measurements
Floor
Looking good! I might have fiberglassed it instead of brazing it but a metal floor is preferred in a car.
Bad news is that there has been a lot of rust found on new xB's all over the country in the wetter climates including mine. The door seam at the top rear corner under the weather stripping gets rusty and one owner pulled up the floor carpeting and found bare metal at a rib rusting badly. |
Any word on the inspection?
Spiders hatching from the passenger door. I believe Tammara would have jumped into oncoming traffic had that happend while she was sitting in that seat when they hatched. |
We just had a patch of spiders hatch on our shed the other day, which I'm now using as the main storage for car parts. Let's just say that a homemade torch with a lighter and an aerosol can can easily kill baby spiders :) |
Good luck on the project though. I feel so dirty worrying about my own project when you're totally owning me. |
editing
Hey the editing of the word fibergl a s s is pretty funny.
Your loose rack should be adjustable - there should be a set screw and lock nut on the end of the steering shaft into the rack. My Geo is still tight and was very tight when new. |
thanks! i was getting a bit tired of working on it, so i'm looking forward to taking a break this weekend.
one of the things the cahttps://images6.theimagehosting.com/m...d-branding.jpg
One thing is for certain, no one would steal it like that :P |
Dropped the torch off at
Update o' the day:
Spent another hour today |
Drivetrain is out of the re
Offsetting might be the best bet.
For the single drive wheel option, you can weld the differential to create a "spool." I think a lot of rally cars have a spool so that they can finish the race even with a broken axle. The disadvantage of this option should be aparent - if you lose traction on your drive wheel, you loose all traction. |
I know there used to be some 1-wheel-drive RC cars, but they were generally RWD. Hard to say how a FWD would react. It probably would pull to the power side and you probably have to give it more gas around the corners where the drive wheel is on the outside, but I don't know for certain. |
Offsetting: one concern that comes to mind is that it puts some lateral load (what's the proper term for that, engineering folks?) on both shafts. I wonder if that might have a negative effect on shaft bearings & seals.
I think doing the offset would add
