-   -   A case against pulse and glide (https://www.fuelly.com/forums/f33/a-case-against-pulse-and-glide-6270.html)
css28 12-14-2007 07:13 AM
U Van Shift Schedule
Here goes:
At 12% TPS (throttle position sensor) value:
1-2 shift will occur at ~13 mph
2-3 shift at ~ 20 mph
torque converter clutch apply in 3rd gear starts at ~ 23 mph
3-4 shift at ~ 40 mph
torque converter clutch apply can start at that same speed in 4th.
At 25% TPS the shift points are 20, 31 and 51 mph, respectively.
Also at 25% TPS the torque converter clutch applies can start at 34 mph in 3rd gear and 47 mph in 4th.
At 50% TPS 1-2 and 2-3 are at 30 and 52 mph. 3-4 won't happen at 50% TPS :) .
With the throttle closed, 4-3 happens at 36 mph and 3-2 at 18 mph.
This should give you something to chew on.
